586,013 active members*
3,801 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > d&m 4s machining center Help on Connector pins
    Sep 2013
    131
    Hi everyone, this horse has been beat a few times before, so any help would be great. I just picked this up and would love to hear it sing. My question is basically, 4 wires red black white and green going into a 5 pin plug/connector. The Sherline will connect to the plugs inside the D&M and will run direct from the computer software,the board in the machining
    center casing has been bypassed I think and the center is just for show maybe.
    All I need is the pins numbers for the 4 wires to be soldered to the 5 pin connectors to plug the PC
    cables into the back connectors on the D&M for the motor and steppers.The wires on the steppers are red green black and white.
    Per diagram, I have red on 6, black and white on 2+5, no yellow or orange wire, just a green one left. Would it go on orange or yellow pin?.
    I would hate to tear my -A- axis cable apart from the PC to see the configuration.
    Sep 2013
    131
    Re: d&m 4s machining center Help on Connector pins
    Any help would be great on the green wire.
    Aug 2006
    671
    I'd take the case apart and see where the 5th wire goes. My original guess was for shielding in the stepper cable, but doesn't look like your cable has a shield....
    Sep 2013
    131
    Thank you.
    Sep 2013
    131
    The steppers are from Oriental motors, not Sherline.
  1. OP connector sanyo denki servo PV drive - looking for connector
    By gm276 in forum Want To Buy...Need help!
    Last Post: 12-15-2018, 07:39 PM
  2. Port 1 Pins current State - input pins flickering on and off in diagnostics screen??
    By ProtoXNH in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-25-2016, 11:06 PM
  3. Remove Pins in Connector - Repair broken wires
    By ontariocnc in forum Maintenance DIY Discussion
    Last Post: 05-04-2012, 06:35 AM
  4. Okk Machine Connector Mould Machining
    By ramnathdn in forum OKK
    Last Post: 03-25-2009, 03:43 PM
  5. Looking for 3 pins metal circular connector
    By rainman in forum Want To Buy...Need help!
    Last Post: 02-09-2009, 02:59 AM
