585,973 active members*
4,213 visitors online*
    Apr 2012
    79
    Fanuc 6m Manual reference return
    Hi, Can anyone help me try to home an axis without actually moving it. I have machine with a fanuc 6mb control and there is an issue with one of the axis motors but i want to carry on using it without that axis. The machine needs to see that axis as "homed" before it will let me carry on. Is there a parameter or grid shift parameter I can change to say the axis is in a homed state. I hope that makes sense.
    Thank you
    Dec 2012
    395
    Re: Fanuc 6m Manual reference return
    Is there a [ Machine Lock ] key on the machine......?
    If soo, key ON and Home the machine, maybe it works.
    Regards,
    Heavy_Metal.
    Apr 2012
    79
    Hi Heavy_Metal
    Thanks for the reply. The machine does not have a machine lock button/key so I cant try that.
    Regards
    Jul 2014
    58
    reach in and turn the ball screw. if the axis doesn't have a break on it, it will move easily.
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 09-19-2023, 12:52 PM
  2. Fanuc EDM Alpha-OC Reference Return
    By frinkdaddy1 in forum EDM Discussion General Topics
    Last Post: 11-12-2020, 08:05 AM
  3. fanuc 18i-m , alarm 90, reference return incomplete
    By azizcom83 in forum Daewoo/Doosan
    Last Post: 11-17-2016, 11:31 PM
  4. APC manual reference position return HELP Please
    By LaserRSTAWD in forum Fanuc
    Last Post: 04-18-2014, 02:53 PM
  5. Yang15ml Fanuc OT manual zero return
    By robertbair in forum Fanuc
    Last Post: 06-30-2010, 01:32 PM
