585,971 active members*
4,017 visitors online*
Page 3 of 3 123
Results 41 to 60 of 60
  1. #41
    Aug 2017
    112
    Re: How to setup kinematics RTCP in KmotionCNC
    Quote Originally Posted by TomKerekes View Post
    Hi Amit,
    This is very strange. The only difference between it working and not working is we added this one line of code:
    if (m_MotionParams.TCP_Active)
    Please help us debug the error. Run the code in Debug Configuration (both Libraries and KMotionCNC) and place a breakpoint on this line and check if m_MotionParams.TCP_Active is true.
    (Of course you must execute G43.4 H1001 first)
    Regards
    Hi Tom,
    Thanks for your reply.
    I tried running different iterations of tcp command using G43.4 H1001 command.
    I found one pattern. in Kinematics5AxisTableAC.cpp file ASaddleZCenterpoint = 0.511811023 is modified in my machine and it is now ASaddleZCenterpoint = 1.023622047.
    Have you included this old value
    ASaddleZCenterpoint = 0.511811023 somewhere. if yes then please change it to updated value ASaddleZCenterpoint = 1.023622047.
    and then compile.
    because When i am running tcp, my tcp optimisation value of Y is always 13 mm more. as i said above center of rotation is 13 mm earlier but its now modified to 26mm.
    kindly suggest me what is wrong in this.
    Thank You
    AMIT KUMAR
    Regards
    Amit Kumar
  2. #42
    May 2006
    4045
    Hi Amit,
    Now I'm confused and don't understand.
    Yes I saw you made that change.
    Have you included this old value ASaddleZCenterpoint = 0.511811023 somewhere. if yes then please change it to updated value ASaddleZCenterpoint = 1.023622047.
    and then compile.
    No that value isn't used anywhere else and you should be compiling not me.
    I don't understand. I'm guessing you think the TCP is not correcting Y correctly because the ASaddleZCenterpoint is wrong.
    Answer 5- yes tcp is working after replacing the old file.
    Because you said you replaced the file and TCP works correctly there should not be anything required to change in other files. Did I understand that correctly?. Did you really replace the old file and prove that it works correctly?
    Regards
    TK
    http://dynomotion.com
  3. #43
    Aug 2017
    112
    Hi Tom,
    I got it can you please compile the Buildall libs file with my ASaddleZCenterpoint = 1.023622047
    can you please send me that same 8 patch files (Index of /Software/Patch/AddG43.4G49_TCP_OnOff_V4.34j)
    that you sent me earlier after rebuilding it with the new ASaddleZCenterpoint = 1.023622047 value in 5axiskinematicsAC .cpp file.
    thank you
    AMIT KUMAR
    Regards
    Amit Kumar
  4. #44
    May 2006
    4045
    Hi Amit,
    Answer 3- yes i compiled.
    Why don't you compile it? I asked before if you compiled it and you said yes.
    Regards
    TK
  5. #45
    Aug 2017
    112
    Hi Amit,
    Regards
    Hi tom,
    I compiled it already but mine is not working after compilation.
    Mine is 13 mm extra optimisations in y direction when a is 90.
    Thats why i want compiled file from your side. With updated asaddlezero point.
    Thank you
    Sent from my Lenovo K50a40 using Tapatalk
    Regards
    Amit Kumar
  6. #46
    May 2006
    4045
    Hi Amit,
    I don't understand why you don't troubleshoot why is is not changing.
    I recompiled the files for you and updated the patch.
    Regards
    TK
  7. #47
    Aug 2017
    112
    Hi Amit,
    Regards
    Thanks tom
    I will try and get back to you.
    I am trying to make your controller, haas competitor.
    Regards
    Amit Kumar
  8. #48
    Aug 2017
    112
    Hi Tom,
    I tried the updated patch files with my machine and everything is working as i wanted.
    Our G43.4 H1001 is working also as well as G49.
    I will continue try running it if any problem occurs i will get back to you.
    Please update the TCP on off Gcode in next update KMotion4.34k. and also update that init and external buttons merged file code into your beta version of KMotion4.34k.
    Thank You
    AMIT KUMAR
    Regards
    Amit Kumar
  9. #49
    May 2006
    4045
    Hi Kumar,
    Great. Thanks for posting back.
    If you find time please try to troubleshoot why you weren't compiling the code. Some things I sometimes do is to put an intentional error in the file that I'm changing. If there isn't an error when compiling I know I'm changing the wrong file. Also check the timestamp on the executable to see that it has actually been re-built.
    Regards
    TK
  10. #50
    Aug 2017
    112
    Hi Kumar,
    Regards
    Hi tom,
    Actually timestamp on the Kmotioncnc.exe file was not changing. When i was trying to compile the code earlier but after you compiled timestamp was changing. How is that even possible.?
    AMIT KUMAR
    Regards
    Amit Kumar
  11. #51
    May 2006
    4045
    Hi Amit,
    Were you compiling the Libraries (BuildAllLibs.sln) or the Examples (BuildExamples.sln) ? KMotionCNC is an example Application not a library. The Kinematics is part of the Libraries.
    Were you looking at the correct Debug or Release directory depending on whether you were building the Debug or Release Configuration?
    Was the build successful? Did the build compile the file?
    Regards
    TK
  12. #52
    Jan 2017
    Hi Amith.
    How are you, Just know i was speaking to Mr.Naveen.
    He told me that you are facing RTCP problem with your controller.
    Need any suggestion call me.
  13. #53
    Aug 2017
    112
    Hi Amit,
    Regards
    Hi Tom,
    I have successfully built and complied the files.
    I am able to turn off the RTCP using G49 but when i try to turn it back on by using (G43,4 H1001), I am not getting the correct results.
    The RTCP is not turning back on in the same state that we turned it off at. I feel that there is some problem with the tool height optimization.
    Awaiting your earliest response.
    Thank you,
    Regards
    Amit Kumar
  14. #54
    May 2006
    4045
    Hi Amit,
    What happens? What State is different? What Tool and Length was selected before?
    Regards
    TK
  15. #55
    Aug 2017
    112
    Hi Amit,
    Regards
    Hi Tom ,
    TCP seems to be working fine by using G43.4 H1001 command.
    It is optimizining according to the tool length in tool table.
    But the problem we are facing is the value mentioned in tool table has to be in inches but the optimization and DRO shows values in MM.
    For example My machine coordinate is Z110 at some point and we are taking tool length of 36mm and value of this tool height i input in tool table of H1001 is 36/25.4 = 1.417 inch.
    So after i turn on G43.4 H1001 command. TCP is working with Z74 (110-36) and it is correctly optimizing.
    But in Machine coordinates (Orange) it is showing Z110. And in Work Coordinates (Green) It is showing Z108.583.
    And TCP optimization is according to Z74. So i want this Z74 to be displayed in work coordinates (green).
    I think the issue is with the value putting to DRO from tool table. Optimization is correctly working.
    Waiting for your kind reply.
    Regards
    Amit Kumar
  16. #56
    May 2006
    4045
    Hi Amit,
    I believe that issue was discussed and solved here:
    https://www.cnczone.com/forums/dynom...ml#post2137030
    It should also be fixed in Version 4.34k. See Changes.
    Note that a bug was introduced in Version 4.34k where Screen Script Buttons that invoke Actions will fail. If you need that functionality you should apply this patch.
    HTH
    Regards
    TK
  17. #57
    Jul 2015
    57
    Hello,
    Can I ask a bit of a basic question?
    I'm looking at building my second 5 axis CNC router. This time I want to have the RTCP path planning in my machine controller, rather than hard-code it into the gcode. I'm just starting to research Kflop and KMotion. Am I correct in saying that KMotionCNC can have its kinematics layer code modified by the user to achieve the desired kinematics to produce RTCP, as well as other path planning logic like limiting rotational motion to a certain angle? For example, a 5 axis machine that has RTCP and will also perform mid-operation C axis unwinds?
  18. #58
    May 2006
    4045
    Hi ChristianLL,
    Sorry I missed this but somehow it was posted with no subject title and so doesn't show on the forum.
    But yes KMotionCNC and our Libraries have a Kinematics Layer you can modify.
    Not sure what mid operation C axis unwinds are. But probably not. You can reset an angular axis to its 0-360 degree equivalent with an MCode.
    Regards
    TK
  19. #59
    Aug 2010
    43
    Hi there
    I'm planning to build a 5 axis router and looking for some answers on the following:
    Does the KmotionCNC software with RTCP work well with the CSMIO/IP - S breakout board?
  20. #60
    Jun 2004
    355
    Quote Originally Posted by vanwyksc View Post
    Hi there
    No.
    KMotionCNC will only work Dynomotion's KFlop
    CS-Labs controllers require either Mach3/4 or their own software (although I have no idea how developed that is now, as last time I heard about it, it was still alpha/beta release with minimal functionality).
Page 3 of 3 123
  1. Replies: 2
    Last Post: 04-12-2016, 03:52 PM
  2. Rtcp g code
    By IN_333 in forum FeatureCAM CAD/CAM
    Last Post: 07-11-2012, 01:53 PM
  3. RTCP
    By emsee in forum Mastercam
    Last Post: 11-29-2010, 08:29 AM
  4. Do you know the difference of RTCP and TCPM?
    By Treva in forum Uncategorised CAM Discussion
    Last Post: 07-11-2009, 02:17 PM
  5. RTCP is different with TCPM?
    By Treva in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-11-2009, 08:47 AM
