585,942 active members*
3,640 visitors online*
IndustryArena Forum > Material Technology > Vacuum forming, Thermoforming etc > VERY Successful DIY Vacuum Former Project
    Feb 2006
    7063
    I needed a vacuum former to make the housings for the milling machine ATCs I sell. After using a Formech machine for several months at a local TechShop, I built my own machine using, mostly, scrap material that was given to me by a friend, and things I had laying around. About the only things I had to buy were the heaters, PID controllers, and plumbing.
    Here is a thread with details on the build: http://www.cnczone.com/forums/novako...mo-former.html
    It works absolutely PERFECTLY - FAR better than I ever dared hope, and FAR better than even the Formech commercial machine I used to use! I use 1/8" ABS, in 24"x24" sheets. The entire sheet heats to an almost perfectly even temperature in under 4 minutes, and forming takes only seconds, with perfect pull-down. Results are absolutely 100% consistent and repeatable, which was not the case with the Formech. The only things I plan to change at some point are really minor some touch-ups (mostly in my crappy welds in the plastic "frame", stronger air cylinders (to ensure solid sealing), perhaps add penumatic clamps for the plastic, to speed loading and unloading, and ,eventually, perhaps automating the whole heat/form/cool cycle, making forming a single-button-push affair. But, for now, I am absolutely thrilled with the results.
    Regards,
    Ray L.
    Sep 2005
    1195
    Re: VERY Successful DIY Vacuum Former Project
    Do you have any video?
    Feb 2006
    7063
    Quote Originally Posted by asuratman View Post
    I don't yet, only because I work alone, and can't operate the machine and a camera at the same time. I will do one at some point...
    Regards,
    Ray L.
    Feb 2006
    7063
    Here is a link to a short video of the machine in action: http://www.cnczone.com/forums/novako...ml#post2087998
    Regards,
    Ray L.
  1. Hobby Vacuum table for a school project
    By Michael1799 in forum Vacuum forming, Thermoforming etc
    Last Post: 03-03-2017, 08:10 PM
  2. Vacuum Forming Machine open source project
    By openforming in forum Vacuum forming, Thermoforming etc
    Last Post: 02-11-2013, 09:13 PM
  3. no more clamps vacuum project
    By Big-tex in forum Work Fixtures / Hold-Down Solutions
    Last Post: 03-17-2010, 09:54 PM
  4. Vacuum working table project
    By FrontLoop in forum Education - Teachers and Students Hangout
    Last Post: 01-14-2010, 07:35 PM
  5. ? on a vacuum form project
    By dragon23 in forum Vacuum forming, Thermoforming etc
    Last Post: 03-18-2008, 05:49 PM
