586,000 active members*
4,953 visitors online*
    Aug 2010
    43
    Material for CNC router Table
    I have a router with an MDF table, 700x1100x21mm. I mostly dry cut brass, and also wood and machinable aluminum. I would like to have a table which would allow me to cut wet. I could get a slotted aluminum table easily enough, but I kind of enjoy just drilling mounting holes where I need them. The first option would be a solid piece of aluminum, but then I would need coolant to drill the mounting holes. I'm wondering if there might be some composite material out there which would be easier to drill, and also be waterproof, and perhaps a bit more durable than the MDF. Any ideas?
    Apr 2004
    5737
    Re: Material for CNC router Table
    Phenolic?
    Andrew Werby
    Website
    I know exactly what will work for you. There's a product called EXTERIA it's a waterproof MDF - it'll hold up well for what you described & it comes in several thicknesses. You may have to have it special ordered from a real lumber yard, Home Depot won't have it. Speaking of Home Depot, they do offer a .5" thick plastic 4x8 sheet for about $80, it's fairly soft and obviously waterproof too. Good Luck!
  1. Table Material
    By robobass in forum DIY CNC Router Table Machines
    Last Post: 10-03-2017, 08:49 PM
  2. hot table to glue material to table
    By tommy78 in forum Uncategorised WoodWorking Machines
    Last Post: 09-05-2014, 07:26 AM
  3. table material idea
    By ashb82 in forum DIY CNC Router Table Machines
    Last Post: 10-15-2013, 08:02 PM
  4. honeycomb table material?
    By bgirit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-26-2008, 03:25 AM
  5. Reference Table for Steel Material
    By nearbeer in forum Mechanical Calculations/Engineering Design
    Last Post: 10-09-2008, 12:08 AM
