585,712 active members*
3,905 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC 4020/HT ATC failure
    Aug 2017
    Hi All,
    I'm working on a Hurco BMC 4020/HT milling machine whose ATC is not working properly.
    I'm able to do all movements, in manual mode, for the ATC: left, right, changing tool position, open door, close door.
    When machine is in auto mode, ATC is not working properly.
    There is not tool in the spindle. If I choose an empty slot for current tool and another slot for next tool, ATC does not move at all.
    If I choose 0 (zero) for current tool and another slot for next tool, spindle goes down, ATC goes right, then machine stops showing "ATC ERROR FOR SELECTED OPERATION".
    I do not know where to look now.
    I'd appreciate if anybody could give some advise to me where I'm supposed to look for.
    Thanks in advance,
    Felipe.
    Jan 2017
    23
    Re: Hurco BMC 4020/HT ATC failure
    Quote Originally Posted by felipe_pem_ie View Post
    Hi All,
    Thanks in advance,
    Felipe.
    Dear I hade similar problem
    Try To go to spindle presing F2 then ATC diagnistic,
    Then you see all posible operation that you can do
    Try look at buttom ATC not at HOME position
    then write here i will give other step by step that to do
    Hurco BMC 2416
  1. Hurco BMC 4020 opinions
    By tfuqua63 in forum HURCO
    Last Post: 03-22-2016, 03:03 AM
  2. BMC 4020 - power supply failure
    By hkenuam in forum HURCO
    Last Post: 02-13-2014, 03:25 PM
  3. Hurco BMC 4020
    By Adtech in forum HURCO
    Last Post: 09-13-2011, 08:21 AM
  4. 4020 fadal spindle orientate failure
    By beekeeper in forum Fadal
    Last Post: 10-09-2010, 10:53 PM
  5. Fadal 4020 Z axis tool change failure
    By ssurfview in forum Fadal
    Last Post: 05-15-2008, 12:48 PM
