Due to relocation I have to sell my brand new 3D subsurface engraving machine. I have imported the machine ad all original receipts (invoices, customs, VAT, warranty) I have on file. Purchasing price including, transport, customs and VAT was around 24.000,00€. Similar machines from European OEM's are significantly more expensive. Sales price is up for negotiation. Pls PN me for more details.
The machine is small in size, not to heavy (less than 100kg), while high performance and capable of mass production as well as single item operations. Easy to use but a training can be provided. Low power consumption.
The machine comes with a design and a control software and computer.
The diode time is currently less than 70h diode time (life cycle = approximately 18 - 20000 hours) and the machine has another 18 months full scale warranty. It is in perfect state and works just great. 3D camera can be purchased optional with software as well as glass material which I sell for purchasing price.
Contacts for material purchase about 50% under European price can be provided as well as OEM contacts for warranty . Training can be provided if required.
The machine is suitable for 3D subsurface engraving of glass and acrylic material.
Technical spects:
Model STNDP-801AB4
Max engraving size (mm) 400*300*100
Max crystal size (mm) 400*300*100
Laser Type Diode pumped Nd:YAG, 532nmgreen laser; 3000Hz
Laser Frequency 4000 Hz
Pulse width ≤6ns
Engraving Speed Maximum: 3500 points/s; 200000dots per minute
Diameter of a point 20-40μm
Repeated location accuracy <10μm
Continuous work time >24 hours
Cooling air
Diode laser module life >20000 hours
Power consumption <800W
Electrical connection Single 220V or 120V (+/-10%); 50Hz or 60Hz
Typical case for normal engraving speed "Crystal size:50*80*50mm pattern:300000 dots Engraving time:<2minutes
Warranty 2 years all
File Format JPG, BM,,DWG,DXF,3DS etc.
Operation demands Temperature:5--35℃, humidity :<70% no condensation
Net Weight 115KG
Machine Size (L*W*H)(mm) 960*760*770
Package Size(L*W*H)(mm) 1240*860*1040
The machine is currently located in Salzburg, Austria. Pls PN me for more details and price.
