585,605 active members*
3,177 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > I just got a PC Mill 125 Does anyone else have one?
    Jun 2006
    5
    I want to get it up and running or if that is not possible, do a conversion on it if the Mechanicals are in good condition.
    Does anyone here have one of these?
    Kevin
    Aug 2006
    44
    Re: I just got a PC Mill 125 Does anyone else have one?
    hello
    maybe I can help you .
    please give me more info
    please contact to my email
    [email protected]
    I am in Los Angeles .
    Did you buy that one in Virginia? The biggest pain is that they are wired for 3 phase power. If you are already setup with 3ph, this is no problem. If everything is in order it should power up. The Fanuc interface works fine. Hopefully it included at least the basic set of toolholders as they aren't exactly cheap from Emco and they are unique to these Emco mills with the turret tool changer. At this age, the boards in the machine begin to act up. I had an intermittent error that I traced to solder connection on the safety board, and still have intermittent error during tool changes. I rewired my machine for single phase as the only thing that really uses three phase is the coolant pump. It makes good parts.
    Jun 2006
    5
    Hi there Diesel_Pilot.
    I just saw your message.
    Yes, that is me, and that is the machine. I am picking it up next week.Can I ask you a few questions about how to move it.
    How much ground clearance is there?
    How many feet does it have on the floor?
    How far apart are they?
    It would be a big help. I am trying to figure out if I need to make some skates to get it out the door..
    Kevin
    It has four bolts threaded into the frame for feet, You'll want to remove them. It moves with a pallet jack, but most of the mass is on the mill side so pay attention to the center of gravity.
  1. Replies: 2
    Last Post: 05-16-2016, 01:08 AM
  2. Replies: 0
    Last Post: 03-27-2016, 04:52 PM
  3. Replies: 0
    Last Post: 02-13-2016, 04:47 PM
  4. Smaller milling machines Bed mill vs plano/fixed gantry mill
    By nilrods in forum Drilling- and Milling Machines
    Last Post: 12-17-2015, 10:34 PM
  5. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
