584,849 active members*
4,457 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > What COOLANT for a 2.2kw liquid cooled spindle
Results 1 to 11 of 11
    Mar 2017
    181
    It's called a Water Cooled spindle so do I just use WATER.....or ANTIFREEZE......ANTIFREEZE "straight"......or what DILUTION?
    Need some advice here...What Say You?
    Re: What COOLANT for a 2.2kw liquid cooled spindle
    Distilled water and good antifreeze. A lot of people use PC water cooling additives rather than antifreeze.
    Jun 2005
    1723
    agree with Ger21, Distilled water, and about 20% car antifreeze. This ensure stuff does not grow in the water. The distilled water ensure there are no impurities in the water to start with like calcium that can accumulate over time and block the passages in the spindle.
    Russ
    Mar 2017
    181
    I was thinking about a good antifreeze and "tap" water...I did not think of Distilled, thank you!
    Jun 2005
    1723
    DO NOT USE Tap Water... It has far to many impurities.
    Russ
    Mar 2017
    181
    Quote Originally Posted by CNCMAN172 View Post
    Russ
    Heard you loud and clear. Going to buy some distilled water right now!
    Mar 2017
    181
    Okay guys...have the distilled water & the Prestone antifreeze. What size of container do I need? I could really use dimensions if you can help.
    I don't want too big that takes up all my storage space yet I don't know what is too small. Any suggestions?
    Aug 2021
    Glad I Googled CNC coolant additive, distilled water never crossed my mind, now I know...
    15362
    Quote Originally Posted by Tomcat104 View Post
    It would depend how long you will be running the spindle it in an open system, start with a gallon in a closed system with a radiator and fan you can have as little as a quart
    Nobody addressed the most important part corrosion the Aluminum spindle core, you have a double whammy because of the Stainless steel outer Aluminum and Stainless steel don't work well together in the unprotected state, so the Aluminum corrosion is the biggest problem, so you have to protect for this more than anything else
    Mactec54
    I'm facing the same challenge. What is the best way to prevent corrosion besides having all of the same material in the loop? Is there another additive or different coolant that can be used?
    15362
    Quote Originally Posted by rossmatt06 View Post
    You need the same as what is used in the auto industry for aluminum engine heads / block protection
    Mactec54
  1. What coolant do you use in your water cooled spindle?
    By DonFrambach in forum Spindles / VFD
    Last Post: 01-21-2017, 01:59 AM
  2. DIY liquid cooled heat exchange electrical cabinet
    By adfergusson in forum CNC Machine Related Electronics
    Last Post: 03-17-2015, 12:44 PM
  3. Water cooled spindle, what coolant do you use
    By TSJ in forum DIY CNC Router Table Machines
    Last Post: 05-30-2013, 12:46 PM
  4. Should I refrigerate my water cooled spindle coolant?
    By davtuner in forum DIY CNC Router Table Machines
    Last Post: 02-09-2012, 06:56 PM
  5. My liquid cooled X2 motor
    By SScnc in forum Benchtop Machines
    Last Post: 09-28-2009, 03:57 PM
