585,715 active members*
4,753 visitors online*
    Feb 2015
    23
    Sudden Y axis problem
    Hi, I have a G Weike LC1390 dual head laser. I’m using Lasercut 5.3. I have been using it for a couple of years now with no major problems.
    Today I was cutting some parts and all was OK until I went to cut another part and suddenly things went a bit strange with my Y axis.
    While the X axis is fine, the Y axis now only moves half way and every thing is only half the height it should be. The heads return to the datum just fine but when trying to move the head to the front of the machine using the cursor buttons the head again stops halfway.
    I’ve switched off and on again numerous times and reloading the configuration file and lasercut and it’s made no difference, the gantry still stops half way between the back and the front of the machine and everything still comes out half the height it should. Checking the setting in laser cut all appears to be as it should. I’m at a total loss as to what to do next. Any help would be greatly appreciated.
    Sep 2005
    1740
    Re: Sudden Y axis problem
    Try moving the Y axis with the power off and by hand. Look for binding in the movement, belt with junk packed up in the cogs or maybe even a bad bearing in the pulleys. It also could be a bad stepper motor, loss of power do to bearings in it going bad.
  1. Z axis problem all of a sudden
    By SplintersWood in forum DIY CNC Router Table Machines
    Last Post: 12-03-2015, 10:20 PM
  2. Need help diagnosing sudden g540 + ess problem
    By usmarine21m in forum Gecko Drives
    Last Post: 09-15-2014, 05:02 PM
  3. X Axis loosing steps all of a sudden
    By Wdwkr53 in forum Mach Mill
    Last Post: 07-12-2014, 12:40 AM
  4. Strange problem with moving X axis all of a sudden
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-27-2013, 10:24 PM
  5. X3 tuning problem / sudden Z axis dives into the stock
    By subnoize in forum X3/SX3/G0619/G0463
    Last Post: 05-11-2013, 04:48 AM
