586,009 active members*
4,884 visitors online*
    Jan 2013
    post processor
    I am aware that I was cheated by Viperplasma and should have known better to by junk but it is what it is. My problem is my computer was hit by lightening so I bout a new refurbished computer loaded with sheetcam, bobcam and mach3 licensed in my name. everything works great except the Z axis. When I hit start and the gantry moves into it's proper location and that where I'm having the issue. My Z axis wants to lift 10 inches then move down 10 inches before making the initial cut. There is not enough gear to allow for ten inches so it kicks my head off and continues to try and lift then reverses into down mode and drops the torch on the table. This is my post processor, Mach 3 plasma. can anybody look at this and tell me where it's going wrong or should I just scrap it? lol.
    function OnAbout(event)
    ctrl = event:GetTextCtrl()
    ctrl:AppendText("Mach3 plasma post processor\n")
    ctrl:AppendText("\n")
    ctrl:AppendText("Generic plasma post for machines without THC\n")
    ctrl:AppendText("Modal G-codes and coordinates\n")
    ctrl:AppendText("Comments enclosed with ( and )\n")
    ctrl:AppendText("M03/M05 turn the torch on/off\n")
    ctrl:AppendText("Incremental IJ\n")
    end
    -- revision 3/2/07
    -- Removed final safety move. This is now done in SheetCam
    -- revision 7/10/05
    -- Added new arc handling
    -- revision 11/7/05
    -- Moved torch to cut height when preheating
    -- Added dummy spindle speed to prevent Mach2 throwing a zero spindle speed error
    -- revision 9/10/04
    -- Added preheat
    -- revision 28/6/04
    -- Replaced startx,y,z with currentx,y,z
    -- created 28/5/04
    -- Based on Mach2 metric.post
    function OnInit()
    post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
    post.Text (" (Filename: ", fileName, ")\n")
    post.Text (" (Post processor: ", postName, ")\n")
    post.Text (" (Date: ", date, ")\n")
    if(scale == metric) then
    post.Text (" G21 (Units: Metric)\n") --metric mode
    else
    post.Text (" G20 (Units: Inches)\n") --inch mode
    end
    post.Text (" G53 G90 G91.1 G40\n F1\n S500\n")
    bigArcs = 1 --stitch arc segments together
    minArcSize = 0.05 --arcs smaller than this are converted to moves
    end
    function OnNewLine()
    post.Text ("N")
    post.Number (lineNumber, "0000")
    lineNumber = lineNumber + 10
    end
    function OnFinish()
    post.Text (" M05 M30\n")
    end
    function OnRapid()
    post.ModalText (" G00")
    post.ModalNumber (" X", endX * scale, "0.0000")
    post.ModalNumber (" Y", endY * scale, "0.0000")
    post.ModalNumber (" Z", endZ * scale, "0.0000")
    post.Eol()
    end
    function OnMove()
    post.ModalText (" G01")
    post.ModalNumber (" F", feedRate * scale, "0.0###")
    post.Eol()
    end
    function OnArc()
    if(arcAngle <0) then
    post.ModalText (" G03")
    else
    post.ModalText (" G02")
    end
    post.NonModalNumber (" X", endX * scale, "0.0000")
    post.NonModalNumber (" Y", endY * scale, "0.0000")
    post.Text (" I")
    post.Number ((arcCentreX - currentX) * scale, "0.0000")
    post.Text (" J")
    post.Number ((arcCentreY - currentY) * scale, "0.0000")
    post.Eol()
    end
    function OnPenDown()
    if (preheat > 0.001) then
    post.ModalNumber (" Z", cutHeight * scale, "0.0000")
    post.Text ("\n G04 P")
    post.Number (preheat,"0.###")
    post.Eol()
    end
    post.ModalNumber (" Z", pierceHeight * scale, "0.0000")
    post.Text ("\n M03\n")
    if (pierceDelay > 0.001) then
    post.Text (" G04 P")
    post.Number (pierceDelay,"0.###")
    post.Eol()
    end
    end
    function OnPenUp()
    post.Text (" M05\n")
    if (endDelay > 0) then
    post.Number (endDelay,"0.###")
    post.Eol()
    end
    end
    function OnNewOperation()
    post.Text (" (Operation: ", operationName, ")\n")
    end
    function OnComment()
    post.Text(" (",commentText,")\n")
    end
    function OnToolChange()
    post.Text (" M06 T")
    post.Number (tool, "0")
    post.ModalNumber(" F",feedRate * scale,"0.0###")
    post.Text (" (", toolName, ")\n")
    if (plungeRate <= 0) then
    post.Warning("WARNING: Plunge rate is zero")
    end
    if (feedRate <= 0) then
    post.Warning("WARNING: Feed rate is zero")
    end
    end
    function OnNewPart()
    post.Text(" (Part: ",partName,")\n");
    end
    function OnDrill()
    OnRapid()
    OnPenDown()
    endZ = drillZ
    OnMove()
    OnPenUp()
    endZ = safeZ
    OnRapid()
    end
    Jan 2013
    Re: post processor
    I don't know how to edit my post and I probably seemed rude calling viperplasma a ripoff but I was frustrated beyond belief. If anybody could please help me I sure would appreciate it. Thank you.
    Aug 2006
    44
    Re: post processor
    Hello ,
    I can help you to startup your cnc plasma .
    Please contact to my email [email protected] , and give me more information about your problem .
    Where are you located ? I am In Los Angeles .
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. Replies: 0
    Last Post: 07-07-2017, 12:56 PM
  3. Replies: 6
    Last Post: 11-04-2015, 05:48 PM
