585,748 active members*
3,863 visitors online*
IndustryArena Forum > CAM Software > Hypermill > centring on hypermill
    Sep 2017
    6
    sorry but i am a totally newbie with hypermill but have used other cam packages
    i am trying to centre drill for drilling but when i calc the path i get the following errors
    milling area definition contains errors
    1 of 1 drill vectors are invalid
    could anyone shed some light on this please
    hi
    first u can creat a job list and u will see part data than after u can defined ur model part.
    than u will select ur drill point and calculate.
  1. Hypermill 3+2
    By Shooter7 in forum Hypermill
    Last Post: 12-21-2015, 08:32 PM
  2. Hypermill and Mach 3??
    By CyborgCNC in forum Hypermill
    Last Post: 10-20-2015, 08:00 AM
  3. pro-e - hypermill
    By yaman in forum Hypermill
    Last Post: 06-22-2009, 06:37 PM
  4. hypermill in amd
    By rokpyle in forum Autodesk
    Last Post: 11-20-2003, 10:44 PM
  5. anyone use hypermill
    By rokpyle in forum Uncategorised CAM Discussion
    Last Post: 08-13-2003, 01:05 PM
