585,937 active members*
3,907 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa AC Brushless Servo Drive
Results 1 to 17 of 17
    Sep 2017
    8
    Has anybody had any experience with Yaskawa SGDB AC servo drives I would like to control them using step direction,
    I am using desk CNC for control but so far I am unable to get any movement on any axis yet.
    This model does have the ability to do this, but it was previously run with an analog signal.
    I do have a digital operator for changing parameters and I feel that this is where I am missing something.
    Would appreciate any help.
    From down under Paul
    Dec 2013
    5717
    Re: Yaskawa AC Brushless Servo Drive
    It looks like it will according to the manual https://www.yaskawa.com/delegate/ope...E-S800-16E.pdf
    See page 556, terminals 7, 8, 11,12
    Jun 2005
    1730
    I have used these type drives with Mach3 with no issues. You will need to set some parameters in the drive and with these drive you need a hand held control which they sell on ebay for about $40. If you have their software you can also do this with a PC and a serial interface, but pretty easy with the hand held controller. You only need one hand held unit to program each drive they are not required for daily operations.
    Russ
    Hand-held
    type
    (JUSP-OP02A-1)
    1-meter(3.3ft.)
    cable
    included
    Sep 2017
    8
    Thanks for that Jim I have this manual and it's quite comprehensive I have connected to 7 and 11 they show using a tri state buffer for controlling the input using 8 and 12 but I am not sure if they are necessary the machine was previously using a num controller just wonder if there is something in the parameters I am missing.
    Sep 2017
    8
    Hi Russ,
    In the manual, they call it a digital operator and my machine came with one of these and I have been resetting the parameters to the best I can work out following the manual
    can you remember anything in particular in the settings or pinouts for step direction control?
    I have enabled the servos to an on state so they are ready.
    Paul
    Jun 2005
    1730
    Will send details tomorrow
    Sep 2017
    8
    I'll buy you a beer if you can help, but I'll probably have to drink it, I'll let you know how it tasted
    15362
    Quote Originally Posted by Krebomatix View Post
    You may already have these Pins taken care of seeing, you have the servos power up
    Have you done the basic jog operation you can do this with the digital operator, these are the first steps to getting everything working, once you have each axes Jogging, then it's time to set the Parameters
    Are you using 3phase power for the Drives ??
    CN1 Pins 1, 2, 5, 8, 10, and 12, connected to Parallel Port GND
    CN1 Pin 7 connected to your Parallel Port Step Pin
    CN1 Pin 11 connected to your Parallel Port Dir Pin
    CN1 Pins 40 , 42, and 43 to ( 0V ) connected to you External 24v DC Power Supply
    CN! Pin 47 ( Enable ) connected to your External 24v DC Power Supply + Positive
    The Parameters that need setting for Step / Dir are Position Control and Pulse Train Reference
    Mactec54
    Jun 2005
    1730
    Krebomatix,
    The Yaskawa drivers come in several variety. The ones that can use position control using Step/Direction signals typically look like SGD-02-BP
    The 02 is the wattage of the driver in this case 200W
    The BP is the important item, the last "P" means the driver accepts position control.Attachment 372380
    The photo shown in a test setup for one of these drivers I am using to control a forth axis servo motor.
    Pin 7,8 are the differential inputs for the PULSE (STEP)
    Pin 11,12 are the differential inputs for the SIGN (DIRECTION)
    You also need to configure the driver, look in the manual and you have to set Cn-2B to a "1" for position control.
    These drivers like differential inputs but can be configured to be driven single ended but I found it works way better with differential signals. Most BOBs do not output differential signals, so you will need converters like those listed below to take the single ended output from the BOB and convert them to differential outputs that get fed into the Yaskawa.
    https://cnc4pc.com/differential-line-driver.html
    There are many parameters in the driver go page by page and ensure the ones you need set are set correctly and you will find these units work great.
    Hope this helps.
    Russ
    Sep 2017
    8
    Thanks so much for that.
    I had not done the 5 8 10 12
    or 4042 43 47 as I had it in the run mode thinking this was enough.
    I'll reconnect these and do a jog.
    Yes 200 volt 3 phase
    Is there anything special I need to do with the brake on the z axis?
    Let you know how I get on in the next couple of days
    Kind Regards Paul
    Jun 2005
    1730
    On the brake initially I would ensure the brake has 24VDC applied which basically turns off the brake. Check the manual for your servo but all the ones I have had used 24VDC for the brake. Ultimately, you can rig something that enables the brake after z gets positioned and just prior to moving to a new height again. This is really only required if you have a heavy spindle. On some of mine I have just left 24V applied to the brake because I do not need a brake. If you fail to put the 24V on the break the servo on Z will not move at all.
    Russ
    Jan 2017
    9
    Quote Originally Posted by CNCMAN172 View Post
    Russ
    Russ - can you update how this was done ? Is it working now
    I have YYaskawa SGDS-01A72 drive - need to see the pins to use -as above
    Please let me know.
    Mike
    Sep 2017
    8
    Quote Originally Posted by Mike58 View Post
    Please let me know.
    Mike
    I see I have failed in a response here I just want to thank all including cnc zone and of course you Russ that the info was spot on and have the machine working beautifully.
    The brake is independent of the servo there is an output from the servo i'd have to check again not hard to find just apply 24 volt and it releases.
    Kind Regards to all Paul
    Jun 2005
    1730
    Glad you got it work. Pretty easy once you apply power for the brake.
    Russ
    Jan 2017
    9
    https://www.cnczone.com/forums/attac...d=420034&stc=1Can someone verify this CN1 connector on Yaskawa
    Jan 2017
    9
    Jan 2017
    9
  1. 1979 model SL-1 yaskawa servo drive and servo problem
    By Redzilla in forum Mori Seiki lathes
    Last Post: 10-31-2016, 07:21 PM
  2. Replies: 0
    Last Post: 10-21-2014, 09:29 PM
  3. Drive for AB brushless AC servo for spindle?
    By Greg Q in forum Servo Motors / Drives
    Last Post: 11-03-2008, 04:42 AM
  4. aveox brushless servo drive
    By panaceabea in forum Servo Motors / Drives
    Last Post: 08-17-2004, 02:20 PM
