585,749 active members*
3,698 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > lost parameters mazatrol T1 on quick turn universal OT-U
Results 1 to 7 of 7
    Aug 2017
    7
    In between me buying the lathe and collecting it some delightful scumbag removed the parameter list. I knew before I bought it that it lost parameters when powered off but was not bothered as it would not be used very often. I have tried downloading a couple of sets of parameters but they are obviously not the right ones. I have contacted Yamazaki UK and although really helpful the machine is so old the engineer that I spoke to had never seen one.
    I can use the lathe without the missing parameters but cant reference it. It also reads 4 times the actual movement, but I just allowed for that when I was using it. The Z axis toggle goes in the opposite direction as well.
    I have attached photos of machine and screen so if anybody out there can help me I would be grateful.
    I am not an engineer by trade but just know the basics.
    Stuart
    Sep 2012
    216
    Re: lost parameters mazatrol T1 on quick turn universal OT-U
    I posted reply on Prac mach.
    Regards Bob
    Jul 2010
    62
    Just wondering if you got it sorted. I have 4 Mazaks with T1 control. I could send copies of parameters and instructions how to reinstall them.
    Aug 2017
    7
    Hello Murphy,
    I am not yet properly sorted with this machine. I can put a combination of parameters in to get it to a point where I can use it manually. This is a really old machine but I am willing to try anything to get it to run properly.
    Stuart
    Aug 2017
    7
    Thanks for replying. My machine was made in 82 so you might be my best chance so far. [email protected].. I can input most of the parameters on page 2 okay. The previous owner who unfortunately died showed me how to input and it took ten minutes and from memory was only a couple of columns on page 2, but as yours are the same age as mine I might try doing both pages.
    Stuart
    Aug 2017
    7
    Hello Murphy,
    If you are not on holiday I dont suppose there is any chance you could send me the parameters for your machines ? I have an angle iron bracket at the left hand end of the lathe with 2 buttons on it that I have not got a clue what its for, any ideas? The whole lot is a mess but that is how it was when I got it.
    [email protected]
    just tried to add a photo but it asks for url so I will put on main thread..
    Sep 2012
    216
    They could have been for a barfeeder or maybe safety fence or similar. I would be inclined to hold them in and see what it does or doesn't do.
    Have sent you some info
    Regards Bob
  1. Mazak quick turn 20 universal prameter help
    By bripley in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-03-2017, 03:04 PM
  2. I need help! Mazak Quick slant 20 mazatrol T-4 Lost parameters.
    By Iliyan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-17-2013, 06:54 PM
  3. Mazak Quick Turn Universal, T-1 Wont Start Up
    By ppc12000 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-18-2011, 01:54 AM
