585,885 active members*
6,103 visitors online*
    Sep 2017
    Anilam 5000M x lag over max help
    Hi there I recently brought a 2004 Quantum S2700D VMC with anilam 5000M control.
    When installed and first fired it up I was getting X & Z lag over max error message when trying to Home axis in
    and servo's would shut down.I played around a bit with adjusting drive belts tension .cleaned limit switches.
    All of a sudden it decided to do as its told and it homed ok.I was off and running.So machine was ok for a couple of weeks
    don a few jobs mill drill & tap.When suddenly it just finish a job under program.an the I put in manual mode started to move
    X table axis along .it moved approx. 300mm then servo,s shut down and it stopped.
    Now does not seem as if it wants to go.Can reference Y axis in and it runs fine
    It can Reference Z in as well but when you try to move it after that it shuts down
    And X Axis is back to shuts down as soon as you hit button to home it.
    Then You Get X lag over max error on screen.
    Has anyone got any other ideas to check what may be cuasing this to happen.
    Closest Technitian is a 1000miles away and will cost fortune to come here.
    Jun 2010
    4256
    Re: Anilam 5000M x lag over max help
    Post city. Someone might be nearby.
    Cheers
    Roger
    Sep 2017
    Thanks Roger
    Machine is in Singleton NSW Australia
    Jun 2010
    4256
    Ah - a bit far from Sydney. Sorry. Anyone else?
    Cheers
    Roger
  1. Anilam 5000m spindle VFD problem
    By gttool in forum Spindles / VFD
    Last Post: 12-05-2015, 08:27 AM
  2. Anilam 5000m uses no G54-G59?
    By machinistgoalie in forum G-Code Programing
    Last Post: 08-24-2013, 08:44 AM
  3. OKUMA OSP 5000M SVPII-0 BOARD
    By keyancnc in forum Okuma
    Last Post: 12-26-2011, 05:03 PM
  4. Anilam 5000m no video input
    By bozrae in forum Controller & Computer Solutions
    Last Post: 08-05-2009, 04:22 AM
  5. OKUMA HORIZONTAL W/ FANUC OSP 5000M
    By TOOLSHOP in forum Okuma
    Last Post: 06-03-2009, 06:56 AM
