584,863 active members*
4,984 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > How to use all 8 Axes in Kflop Board Connected with Kanalog Board
Results 1 to 13 of 13
    Aug 2017
    112
    Hi Everyone,
    I have one Kflop Motion Controller connected with Kanalog Board.
    And after connecting Kflop JP7 to Kanalog JP14. For using 8 axis i have to multiplex JP7 to JP4 and JP6 due to Kanalog board connections.
    But after connecting as i have seen in documents
    Note that the first 8 of 10 I/O pins of Aux #0 and Aux #1 have internal 150 Ohm pull down resistors. Therefore Pins JP4-13, JP4-14, JP6-13 and JP6-14 may not be used in Open Collector mode.
    i have limitation of using only 6 out of 8 axes in STEP/DIR mode.
    What does it mean ? or how to use STEP/DIR in JP4-13, JP4-14, JP6-13 and JP6-14.
    and i have requirement of using all 8 axes. But due to pin limitation i can't use.
    Please help me in running all 8 axes after multiplexing from JP7 to JP4 and JP6 in Kflop Board.
    Thank You
    Regards
    Amit Kumar
    May 2006
    4043
    Re: How to use all 8 Axes in Kflop Board Connected with Kanalog Board
    Hi Amit,
    It just means that those 2 channels only operate as 3.3V LVTTL mode. If your drives accept LVTTL signals they can be used. Actually the specifications for 5V TTL and 3.3V LVTTL are the same (High level must be 2.4V). If your drives require 4.5V you can add an external driver. Such as:
    https://cnc4pc.com/differential-line-driver.html
    HTH
    Regards
    TK
    http://dynomotion.com
    Aug 2017
    112
    Hi, Tom
    I used an External Driver Which supports 3.3V LVTTL mode. And i connected in the pins of JP4 13,14 and JP6 13,14.
    I tried running Axes U and V by Manual input. But Both the motors are rotating in 1 direction smoothly. When i reverse the direction by inputting U-10 or V-10. Steppers are vibrating too much and there is no smooth motion. even it is not stopping while running in opposite direction untill i turn off the power.
    and What is the Difference between output chan0 and output chan1 in initialization file ?
    Please tell me the solution for the U and V axes also.
    Thank You
    Regards
    Amit Kumar
    May 2006
    4043
    Hi Amit,
    Did you connect a GND? How is it wired exactly? How are the axes configured? Please use the Step Response Move command to first test your axes motion not GCode.
    Some Output Modes require two output devices. In those Modes the Two Output Channels specify the devices. For Output Modes like Step/Direction there is only one output device (one Step/Dir Generator) and only OutputChan0 is used.
    Is the 5 Axes AC Tunnion Table RTCP now working?
    Regards
    TK
    Aug 2017
    112
    Hi Tom
    Yes i connected GND.
    I am using a tmc driver for stepper motor. Step and Dir are connected to kflop board JP4 Pin 13 and Pin 14. and for powering up driver i am using external power supply.
    Axes are configured using output channel 0 to 6. as Step and Dir Generators are 0 to 6 i am using.
    Yes i tried step response move command but that axis is only running in one direction. in other direction i am getting jerky movement.
    Please solve this problem i am facing.
    Thank you
    Regards
    Amit Kumar
    May 2006
    4043
    Hi Amit,
    What tmc driver are you using? Do you have the interface specification?
    To use LVTTL mode you must add 8 to the channel number. So you should be specifying OutputChan0 as values 8-14 not 0-6. Are you doing this? See channel Table here:
    Step and Direction Setup
    Regards
    TK
    Aug 2017
    112
    Hi, Tom
    I am using A4988 Stepper Motor Driver Carrier driver, Here is the link for driver and interface specification.
    https://www.pololu.com/product/1182
    Yes i added 8 to channel number also. and using values 8-14 to outputchan0.
    Now please help me regarding connections of this driver to kflop board.
    Thank You
    Regards
    Amit Kumar
    May 2006
    4043
    Hi Amit,
    What Logic power supply are you using? To be TTL compatible it would need to have a 3V power supply. The A4988 Logic High requires 0.7 x Vdd. For Vdd=5V the high level would be too high 3.5V. A true TTL input should only need 2V for a valid high level.
    Regards
    TK
    Aug 2017
    112
    Hi Tom
    I am using a regular computer SMPS which has supply for 3.3V as well as 5.0V.
    What if i want to use Normal mode for all 4 Linear axes X,Y,Z,U not LVTTL ? and my A, B, C are already used.
    Is there any way of using that.?
    Thank You
    Regards
    Amit Kumar
    May 2006
    4043
    Hi Amit,
    Which are you using?
    I'm not sure what you mean. By "Normal mode" do you mean Step/Dir Generator 5V Open collector mode? If you do not multiplex the Step/Dir Generators then all 8 can be used in 5V Open Collector mode or TTL mode independently. If you do multiplex Step/Dir Generators to KFLOP JP4 and JP6 then 2 can only be used in TTL mode. If you need 5V signals on those 2 you will need to add an external line driver.
    Regards
    TK
    Aug 2017
    112
    Hi Tom ,
    Which are you using ?
    I am using open collector step/dir mode.
    Which line driver i should use to make kflop board JP4 Pin 13 and Pin 14 to work with open collector step/dir mode for +5V.
    Waiting for your kind reply.
    Regards
    Amit Kumar
    May 2006
    4043
    Hi Amit,
    You might use:
    AM26C31CDR
    Texas Instruments IC QUAD DIFF LINE DVR 16-SOIC
    Or a 3rd party module such as:
    https://cnc4pc.com/c72-differential-line-driver.html
    Regards
    TK
    Aug 2017
    112
    Hi Tom,
    Thanks for the reply i will let you know about the updates.
    Regards
    Amit Kumar
  1. Kflop with Kanalog board Question: Can I also control Steppers?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-05-2015, 04:30 PM
  2. 5 Servos on a Kanalog board
    By gfacer in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-29-2015, 07:51 PM
  3. Daughter board for KAnalog
    By arvidj in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-10-2013, 10:23 PM
  4. Problems with isolations still connected to board
    By hudsonlighting in forum PCB milling
    Last Post: 10-06-2010, 09:30 PM
  5. 24V supply leaps to 35V when driver board connected!
    By HankMcSpank in forum Stepper Motors / Drives
    Last Post: 08-26-2008, 10:27 PM
