585,670 active members*
4,334 visitors online*
IndustryArena Forum > CAM Software > Surfcam > surfcam port machining
    Feb 2006
    49
    has anyone had success in getting 4 axis multi cut to port machine well?, what I mean is without a ton of crap moves inside the port. i have cleaned it up a bit but it seems like I'm never going to get a clean path. any help would be great, i am not a slouch on this software but maybe I'm missing something. thanks for any help.
    Feb 2006
    49
    Re: surfcam port machining
    Quote Originally Posted by camaru View Post
    just so people know this does work ok, I had to spend hours to adjust things but I got good path, no need for the port option,
    May 2006
    803
    Did you divide or re-flow the surface UV to direct the paths?
    Been doing this too long
    Feb 2006
    49
    Quote Originally Posted by bostosh View Post
    No although that would effect the path but I took the time to make adjustments to every thing it took a few days between it and everything else and its on 4 axis so I have to assume on 5 axis it would be even nicer path.
    thanks
  1. Replies: 4
    Last Post: 11-18-2016, 11:47 PM
  2. 3d machining in surfcam
    By james1984 in forum Surfcam
    Last Post: 06-16-2016, 08:40 PM
  3. Replies: 0
    Last Post: 12-16-2014, 05:17 AM
  4. Port Machining Issue
    By studentmatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-19-2014, 04:41 PM
  5. Surfcam velocity 3.0 Flat Surface Machining
    By jamesr in forum Surfcam
    Last Post: 09-22-2007, 03:52 AM
