585,974 active members*
4,318 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Smoothstepper ethernet or Xhc Mk4-v 4axis ethernet?
    Jun 2012
    49
    Smoothstepper has 6axis, cost little more with breakout terminal, and c41 pwm speed control around $270 capable mach3 and mach4? Made in where??
    Xhc mk4-v 4axis ethernet 2000hz about $210 got everything build in, pwm speed control, all terminal, made in China*
    I'm more familiar with Xhc because I used to have one. Smoothsteper it's something new to me. ((I need a board that are quite low noise, fwd,stop,cw rotation by software, cut thread milling, tap, readout RPM))
    Re: Smoothstepper ethernet or Xhc Mk4-v 4axis ethernet?
    Smoothstepper is made in the USA, I believe. It's at least designed and supported in the USA.
    I would not buy ANY chinese motion controller, unless you know for certain that every function that you need works with it. Most do not support full Mach3 functionality.
    Dec 2009
    166
    Best thing I ever done was to buy a Ethernet Smoother Stepper
    Jun 2012
    49
    Where is the cheapest place to buy smoothstepper?
    And do I even need board terminal?
  1. Want to buy used Ethernet SmoothStepper
    By Azalin in forum Want To Buy...Need help!
    Last Post: 03-28-2016, 09:33 AM
  2. help smoothstepper ethernet!
    By Cam4ge in forum SmoothStepper Motion Control
    Last Post: 04-30-2013, 11:58 PM
  3. Smoothstepper (ethernet)
    By t300 in forum Novakon
    Last Post: 09-08-2012, 02:43 AM
