585,717 active members*
4,034 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Open vectors??????
Results 1 to 6 of 6
    Jul 2015
    7
    Open vectors??????
    Hi, I have just started using Aspire although I've been reading different threads about it.
    I am having problems with Open Vectors, I've tried everything possible, I've clicked on the
    tab to close vectors but the join tab is greyed out.
    Could somebody please explain step by step,
    I've got a word ready to go to be cut, I click on show all open Vectors and
    half the letters are closed and the other half are open, I click on the join vectors
    tab but the join tab is greyed out.
    What do I do now, I've checked that there is no obvious vectors open ??
    Sorry hope you understand this, but I've been trying to sort it for 5 days,
    getting no where
    Mar 2008
    1762
    Re: Open vectors??????
    What version do you have? There are different features added in the newer versions
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Jul 2015
    7
    Hi it's Version 8
    Jul 2009
    56
    First, select all open vectors... (Edit | Select all Open Vectors), then Edit | Join Vectors (J)
    Enter a tolerance value within which the openings in vectors selected will restricted to in order for the Join Vectors operation to select and complete...i.e., if the Tolerance is smaller than the gap in the open vector, that vector will be excluded from being a selected target of the Join Vector command.
    So make the Tolerance large enough for the Join Vector to occur.
    This will close the vectors where gap is less than the tolerance.
    Jul 2015
    7
    Thanks very much Kieth.
    There is so much to learn and remember.
    Jul 2018
    6
    Also I've run into situations where there's a few tiny spots or duplicate vectors that are almost impossible to see. So I Hit Shift and manually click on the vectors and move them to another spot on the material to see if there's a hidden open vector underneath.
  1. Noob Struggling - with open vectors
    By enterpryse in forum ViaCad / Shark
    Last Post: 02-29-2016, 11:43 PM
  2. Vectors
    By jmerson in forum Dolphin CAD/CAM
    Last Post: 05-19-2010, 07:18 PM
  3. Smoothing vectors help
    By SScnc in forum ArtCam Pro
    Last Post: 05-05-2010, 02:32 PM
  4. Vectors
    By cijunet in forum Mastercam
    Last Post: 02-13-2007, 03:05 AM
