They attach directly to the outside of the cylinder and sense the magnet in the piston through the cylinder wall. I recommend you get the cylinder and sensors together. They are kind of a matched set. Electrically they aren't anything special, just hall effect sensors, but their shape helps make a secure attachment to the cylinder. Also, a lot of cylinders already have the magnet in the piston. You might be able to get any suitable hall effect sensor to work.
They are only made for pneumatic generally. As these are usually aluminum cylinder, the hydraulic kind use a steel cylinder usually and the sensors I mentioned in PM do not work on these.
Magnet senors do not work on steel.
I have several 2 wire kind with LED indicator.
Often they attache with a jubilee style clamp that can be adjusted for position on the cylinder.The piston carries a magnetic ring on it.
Al.
Albert E.
Just an awesome thing, I feel sovereign) The signal on the radio catches perfectly, I work from any corner of the apartment. The principle of operation on the relay. -minus: The outlet from the network itself is enough somewhere ~ 5w, there is a slight heat. - the design is not thought out a bit as it is not possible to stick a filter in the network next to two, which is too thick; So only once,
I disassembled one socket on the button for the computer to turn it on remotely. As a result, from yusb through the booster filed somewhere 15v directly after the diode (this was enough for the relay to work, initially it was more, the volt ~ 24v could be mistaken already forgotten)) and it already consumes 0.3w and then with the relay closed, and of course it does not heat up .
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
