Hello to all...
Does any know, how to edit PLC LADDER directly on machine, or witch program can be used for modify PLC.
Controler on machone is Mitsubishi M730MB.
I need to change one output signal (Y) to some difrent output signal.
Reason: on I/O bord is brokem Y signal and new I/O is too much money to spend. This Y signal is from coolant pump for chip flud coolant under B axis.
Thank you all for your help or sugestions how to fix the problem...
BR...
