I want/need to retrofit a large (14'wide gantry) ESAB Avenger 1 Plasma table with two 600 amp heads that was purchased at auction.
I have been looking at my options. With MACH4 I could maybe get the second head to work as a slave to the first one and just have another setup when only using one head. Pretty much leaning towards VitalSystem complete Ethernet closed loop system with Yaskawa drives. if I go this direction.
I want to keep this as simple (Ethernet wherever possible) and professional as possible not worried about saving a few dollars here and there. But, am an experienced programmer so having the power and flexibility these "hobby" systems provide is very attractive... Oh saving $50K is not bad either.
So far it seems to me UCCNC is a replacement for Mach3, and is still all serial cable stuff???
SO: Would like direction on:
Which software to use for plasma?
Are two heads possible?
If I do go CNCNC, what is the simplest closed loop cards that are recommended?
What THC with that card system?
Thanks much for anyone's time and input.
