585,560 active members*
3,419 visitors online*
    Sep 2005
    272
    Feed hold stops spindle
    2004 doosan puma 240 fanuc 21i tb anybody know what keep relay I need to change so the spindle dont stop when using feed hold? thanks
    2932
    Re: Feed hold stops spindle
    I believe it's K3.0 (there should be a list of keep relay settings in the "blue book").
    From the operator's manual:
    K3.0 Set "0" Feed hold operates but spindle and coolant don't stop.
    Set "1" Feed hold operates and spindle & coolant stop.
    However, in case of executing fixing cycle for thread cutting
    or tapping, operation will be stopped after finishing
    actual machining part.
    Sep 2005
    272
    Thanks dc you are rite on the money, works the way I want'ed it to, dont know why anybody would want the spindle to stop with a feed hold but anyway thanks again!
    2932
    You're quite welcome. I remember the first Doosan (Daewoo at that time) I ran, I thought, "How handy, I don't have to stop the spindle and coolant!" That feeling lasted about 2 minutes into proving out my first program. Then I thought, "What a PITA!"
    Jan 2010
    321
    I have a 8s and a 10hc. The 8s spindle stops the 10hc doesn't. I quite like that it stops. Great to clear a bird's nest or change an insert mid rough cut. Check clearance to the jaws in dry run.
    The worst part is if you open the chuck during this feed hold condition as soon as the chuck closes the spindle starts up. That is down right dangerous.
  1. Replies: 6
    Last Post: 11-18-2020, 07:41 AM
  2. Replies: 6
    Last Post: 08-04-2015, 03:53 PM
  3. feed hold with t-command
    By kwh in forum Auto Tool Changer
    Last Post: 08-23-2014, 12:58 PM
  4. Feed Hold
    By HelicopterJohn in forum Haas Mills
    Last Post: 04-25-2008, 03:57 AM
  5. What should Feed Hold actually be??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 01-22-2006, 07:04 PM
