585,597 active members*
3,061 visitors online*
    Sep 2017
    K40 laser will align but not cut or engrave
    Recently purchased K40 laser engraver off eBay. Arrived undamaged. It aligned with no problems. Installed Corel LaserDraw. Entered machine model and id and laser is connected. When I send job to the laser it will move as if it is performing the pattern but no laser cutting or engraving occurs. Checked power supply and DSP board. Power supply works and test is green when button is pressed. Again, the laser will fire for aligning but not for cutting. Any ideas?
    Shanec
    Jan 2017
    40
    Re: K40 laser will align but not cut or engrave
    Is there a test function? Try a test if nothing open the back and see if bulb is on. It will be a light blue. Those machines can be a pain.
    Apr 2003
    540
    Go to the google group/commuity "K40 LASER CUTTING ENGRAVING MACHINE"
    a simple search will find it. Explain & ask there and I've no doubt they will help.
  1. CO2 Laser Mark-Help laser machine engrave glass in blue color
    By CO2LaserMark in forum Commercial Laser
    Last Post: 04-11-2017, 05:55 AM
  2. Laser cutter software RDworks v8 tutorial 04 How to Align Objects
    By AmyThunderlaser in forum Thunder Laser
    Last Post: 12-30-2015, 08:15 AM
  3. laser mirror align problem, OR NOT
    By kern95 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-17-2015, 10:55 AM
  4. Align beam in laser engraver
    By siciait in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-01-2012, 03:14 AM
  5. Align Honing or Align Boring ?
    By jonbanquer in forum MetalWork Discussion
    Last Post: 11-09-2008, 04:33 PM
