585,994 active members*
4,600 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Short cycle time job, lots of parts - Anyone leave spindle running?
Results 1 to 9 of 9
    Jun 2017
    53
    This morning I had an easy 1 op, 3 pass job to do on 50 pieces. Before May of this year, I would have done this on my old manual Burke mill and left the spindle running the whole time.
    So, after a few editing trials I accomplished this on the Tormach by removing the M5 and M30 from the program. Worked great, however, the actual job cycle time was only 20 seconds and I noticed PathPilot waited 8 seconds ramping the RPM up on screen (even though the spindle was already at full chat) before proceeding with the initial Z plunge after each cycle start. So, it could have been a 12 second cycle or 40% of the total job time waiting on phantom spindle ramp-up time. Anyone work around these time losses on large, short cycle jobs? Maybe there's a more elegant way to accomplish what I wanted?
    Safety, lawyers, dismemberment, I know....
    Feb 2006
    7063
    Re: Short cycle time job, lots of parts - Anyone leave spindle running?
    Why on earth does it waste time ramping RPM? Every machine I've owned would get up to max RPM (6000-8200 RPM) in well under a second. They would all stop almost as fast.
    Personally, I think doing ANYTHING while the spindle is running is just begging for injury. I don't even like having a tool in the spindle with the spindle off when I'm re-loading a fixture.
    Regards,
    Ray L.
    Jun 2005
    656
    I asked Tormach about it a while back and they said something like the delay wasn't variable by speed as some sort of LinuxCNC limitation and thus set to make sure it wouldn't be a problem for max speeds. Also they wanted to make sure coolant was actually flowing onto the part to avoid wadding up end mills with aluminum.
    Jun 2014
    1780
    Quote Originally Posted by 74BurkeMVN View Post
    I had that problem on a conversational facing op, turns out that the spindle delay to full rpm was set to 5+ seconds in the .ini file, I changed it to 2.5; and all was good.
    mike sr
    Jul 2011
    400
    I guess I'll look at it from the safety angle. Rotating spindles are dangerous. One wrong move and you touch the spindle you get hurt. A moment of inattention and there is blood. I would figure out how to adjust the ramp up speed of the spindle and do that. A couple of seconds waiting is a lot better than having skin and bone removed by an end mill. I'm not a big safety guy but I had an incident with nitrile gloves and an air drill years ago. It was a painful bloody lesson I will not repeat.
    Jun 2014
    1780
    I changed line # 145 to 2.4 seconds.
    This file is modified to my liking, but changes to the seconds entry in line 145 is what I did to speed up the spindle ramp up time for a facing op in conversational, it has been a year or so but this is to the best of my recollection.
    This file is tormach_1100-3.ini that needs the mod
    mike sr
    Mar 2009
    1863
    Any time you program a M1 or an M0 the spindle is going to stop.
    You don't need to program M5, M30 to stop the spindle. Once the control sees M30 (program end, reset) all function for that program is turned off and the program resets to the beginning.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jun 2017
    53
    Quote Originally Posted by popspipes View Post
    Thank you thank you thank you!!!
    Mar 2009
    1863
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Ray's right. It only takes a few seconds for the spindle to start and I like all my fingers right where they are.
  1. Replies: 3
    Last Post: 04-27-2015, 04:09 PM
  2. Running short on time...
    By SSLLC in forum PlasmaCam
    Last Post: 05-08-2014, 12:06 AM
  3. Replies: 0
    Last Post: 04-24-2012, 01:46 PM
  4. lots of question, just one at a time!
    By XC700RMK in forum BobCad-Cam
    Last Post: 02-21-2012, 06:54 PM
  5. Do you leave your cnc mill running unattended?
    By slashmaster in forum Benchtop Machines
    Last Post: 06-10-2009, 07:05 PM
