585,581 active members*
3,767 visitors online*
    Jun 2017
    143
    Powering Mk3/4
    The manual says the external power is 8-24V @200mA. Is this external supply really needed when connected to a computer since the board is supplied with power from the USB port. A standard USB2 port can supply 500mA. I am confused as to why a separate power input is required in this situation. I would have thought you would only need to connect it if you had no computer and where using an SD card for the g-code.
    Cheers
    Simon
    Mar 2017
    1304
    Re: Powering Mk3/4
    External power supply is really needed. Without it controller will be unstable.
  1. SL-2b Powering down during operation
    By GetMfg in forum Mori Seiki lathes
    Last Post: 03-25-2012, 04:17 PM
  2. Powering up an older KM3
    By rbalister in forum HURCO
    Last Post: 06-23-2011, 01:26 PM
  3. Tree not powering on
    By MadPickinSkills in forum Tree
    Last Post: 01-29-2011, 06:51 AM
  4. G540 not powering up
    By Turbo1zz in forum Gecko Drives
    Last Post: 11-18-2009, 05:00 PM
  5. 6M Powering up alarm
    By TR MFG in forum Fanuc
    Last Post: 11-17-2008, 11:14 PM
