586,000 active members*
4,956 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > MX4660 Input 5 not working
    Jan 2017
    31
    Well, I looked and looked and I could not find a solution to my problem. Hopefully someone here can help.
    I have a Leadshine MX4660 controller with a SmoothStepper Ethernet connected to it. Port1 from the ESS is connected to the DB25 of the MX4660 using ribbon cable.
    I'm using Mach3 software
    I've been using the machine for a few months with no problems.
    Then yesterday...
    I'm trying to get a Z-Home switch installed.
    Input1 is used for X, Y, and Z (UP only) endstops (Port 1 Pin 10)
    Input 2 is used for X Home (Port 1 Pin 11)
    Input 3 is used fro Y Home (Port 1 Pin 12)
    Input 4 is used for the tool touch probe. (Port 1 Pin 13) (not sure if I need this)
    All these switches work.
    Also my E-Stop switch works.(Port 1 Pin 15)
    I wired the Z-home switch to the Input 5 terminal of the MX4660
    Assigned Port 2 Pin 10 to Z-Home
    I do not see the switch getting activated in the Mach3 Diagnostic when it is pressed.
    Did I miss something ?
    Re: MX4660 Input 5 not working
    Did you ever figure this out?
  1. Replies: 3
    Last Post: 11-03-2011, 02:25 AM
  2. G540 input 1 not working !
    By Action-KAT in forum Gecko Drives
    Last Post: 05-12-2011, 07:08 PM
  3. RS232 DNC input not working
    By dingo0722 in forum Haas Mills
    Last Post: 12-11-2010, 01:48 AM
  4. Working on Design - Looking for Input
    By Jesse B in forum DIY CNC Router Table Machines
    Last Post: 03-24-2010, 04:55 AM
  5. G540 input not working?
    By stoneyreef in forum Gecko Drives
    Last Post: 05-08-2009, 07:52 AM
