585,954 active members*
4,111 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Anilam 6000m Memory Protection Fault - invalid command.com
    Jul 2012
    9
    Machine has been sitting for about a month or so.
    Fired it up, had an issue with not booting up, turned out the CMOS battery had died, reset the date and it didn't match the time on the HDD-got that resoved, now I have the following issue/error trying to get to 'home':
    Abnormal program termination: Memory protection fault
    CS:EIP = 000Ch:00153F75h
    Invalid COMMAND.COM
    Cannot Load COMMAND, system halted
    Have reloaded all setup disks for ANILAM, Machine loads and starts fine:
    Servos reset fine.
    But when you push the home button, it moves for a few seconds and then the above error occurs and the whole machine/system freezes.
    Any ideas/help would be greatly appreciated.
    Curtis
    Mar 2017
    6
    Re: Anilam 6000m Memory Protection Fault - invalid command.com
    I have bought CNC milling machine with Anilam 6000M,
    Is any system, control battery I should carry out?
    Regards
    Krystian
  1. Anilam 6000M control
    By FranschTech in forum Controller & Computer Solutions
    Last Post: 11-03-2023, 04:34 PM
  2. Anilam 6000m controller
    By anilam in forum Controller & Computer Solutions
    Last Post: 02-18-2016, 07:44 AM
  3. Anilam 6000M Halted during G84
    By hadulzo in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2012, 03:52 AM
  4. anilam 6000m
    By slug in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2009, 07:39 PM
