585,917 active members*
3,537 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Single relay for cw and ccw direction is possible in mach3 with G540?
Results 1 to 3 of 3
    Mar 2016
    68
    Hi guys! I'm in the process of finally getting to work my Sieg C1 Cnc conversion..
    I've got a doubt on wiring the relays...
    I used two 48V relays, one wired to turn on and off the spindle, attached to one of the G540 outputs,
    and one relay DPDT wired in a way that depending if it's on or off, reverses the poles of the spindle, connected to the other output.
    I thought that in Mach3, I could set up a single output to rotate the spindle in both directions, just by setting one rotation to active high and the other to active low.
    But in the motor setup page of Mach 3, I need two outputs, one for each rotation.
    Is there a way to set up mach3 the way I wired, one relay just for on/off and the other to control the direction of rotation based on high and low, at the same port, or do I need to rewire the relays in order to have one relay to turn on in one direction, in one output, and another in the other direction, in the other ouput? And then wouldn't need the on/off relay?
    Thanks for reading!
    Mar 2016
    68
    Well, I ended rewiring the relays so one has the wiring for cw, and the other for ccw, in separate outputs. It worked normally. I guess it’s not possible the way I thought in Mach 3
    Quote Originally Posted by Rimbaldo View Post
    Thanks for reading!
    Nov 2012
    1267
    Re: Single relay for cw and ccw direction is possible in mach3 with G540?
    You could use a diode to wire the relays so that the CW output activates just the "ON" relay and the CCW output activates both relays.
  1. VFD P24 to G540 using a Relay
    By district7 in forum Spindles / VFD
    Last Post: 04-25-2015, 06:56 PM
  2. Replies: 3
    Last Post: 10-21-2014, 10:19 PM
  3. Gecko G540 Relay's Need Help
    By The CNC Man in forum DIY CNC Router Table Machines
    Last Post: 02-09-2010, 12:16 AM
  4. Gecko G540 Relay Help
    By The CNC Man in forum Stepper Motors / Drives
    Last Post: 12-03-2009, 11:11 PM
  5. G540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-22-2009, 03:03 PM
