586,009 active members*
4,728 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > MSC Surface Grinder Questions/Tips
Results 1 to 3 of 3
    Jun 2010
    119
    I have a clone of this surface grinder from MSC https://www.mscdirect.com/product/details/09517970 . The brand is Lincoln if it makes a difference. I'm having issues getting a smooth grind with it. I've trued the wheels, balanced them as well as I can, although I'm new to doing that. I tightened the Z axis up to where it is almost difficult to move. No matter what I do I can't seem to get a nice grind. It always looks scalloped. I've tried very light cuts and heavy. The bed moves nice & smoothly, I can't feel any chatter in it.
    Does anyone have any suggestions to get it to work better? I made a quick balancing shaft for it, but I'm not sure if it is any good. Is there a place I can get a decent one?
    Thanks!
    Mike
    Dec 2013
    5717
    Re: MSC Surface Grinder Questions/Tips
    You might need to use a different wheel. It depends on the material that you are grinding. Normally you would use a harder wheel for softer materials and a softer wheel for harder materials. What material are you grinding?
    Jun 2010
    119
    Thanks for the tips. I'm not too sure, it was a block that came with it. Although I ground the magnetic table & it did the same thing. A friend have me a good wheel & it did the same thing.
    I ordered a good balancing spindle & checked my wheel with it tonight, it seemed to be well balanced. I'll check the wheel hardness tomorrow.
    Thanks.
    Sent from my Pixel XL using Tapatalk
  1. building manuel surface grinder and a od grinder
    By toolsrule in forum Benchtop Machines
    Last Post: 12-02-2015, 11:20 AM
  2. Surface Grinder Help
    By mtparker18 in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2013, 11:41 PM
  3. Tips Needed for Toolpost Grinder and Wheel Selection
    By cjjonesarmory in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2012, 08:40 PM
  4. Please help! Surface grinder questions.
    By tntmachine in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2007, 07:54 PM
  5. Building CNC Surface grinder - whole lotta questions
    By rashid11 in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2006, 09:53 PM
