hello to everyone, i need your help!
I connected an SSR relay to the DB25-1205 board by putting the negative input of the relay, the GND of the breakout board and the positive contact, the PIN17
then I configured Mach3 putting output 1, port number1 and PIN17, to the AC socket where the engine of my lathe will go.
I managed to turn the engine on and off using the SPINDLE command of Mach3, but my problem is that when I open Mach3 the motor starts, without I running the SPINDLE command, and the screen does not tell me that it is on. when I push the SPINDLE command, the motor stops, but in the Mach3 screen, the spindle is switched on.
Basically, I should invert the way the relay is energized and the signal from the current socket, how should I do it? what am i wrong with wiring ??
help me ?! thank you
Basically, I should invert the way the relay is energized and the signal from the current socket, how should I do it? what am i wrong with wiring ??help me ?! thank you
