585,987 active members*
4,552 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > HELP!!!!!Can I regenerate vectors from saved g-code
Results 1 to 6 of 6
    Sep 2017
    Hi All!
    Whilst programming our power bombed out at the workshop I had already started pocketing when I noticed a problem. The file was still open on my PC as I was still in the process of finishing the next profiling toolpath.
    Went back to the PC to redo pocketing ,was busy moving and placing vectors onto correct layers. Didn't hit "SAVE' and the power went out. Is it possible to create vectors from g-code???
    Any help would be greatly appreciated,
    TIA Kevin
    Sep 2006
    6463
    Re: HELP!!!!!Can I regenerate vectors from saved g-code
    LOL....sorry.....you need a UPS to keep the show on the road when you have a sudden power out.
    Ian.
    Jun 2010
    4256
    Yes, it is possible, because the g-code should be an exact reproduction of the design.
    However ... it can be extremely difficult.
    Cheers
    Roger
    Sep 2017
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Found a G-code ripper that converts gcode to dxf.
    Jun 2010
    4256
    A ripper.
    Dear me - that would do it I guess. And accurate too.
    Lucky!
    cheers
    Roger
    Apr 2004
    733
    Gcode ripper works great. Used it to recreate a lost vector file from the gcode program a couple months ago. The program has some other nice features too.
  1. Regenerate toolpath shortcut key
    By bel630 in forum Mach Software (ArtSoft software)
    Last Post: 01-05-2012, 05:52 PM
  2. mach3 regenerate toolpath shortcut key
    By bel630 in forum DIY CNC Router Table Machines
    Last Post: 01-05-2012, 03:07 PM
  3. X4 won't regenerate properly
    By kprice1658 in forum Mastercam
    Last Post: 04-03-2010, 08:16 PM
