585,753 active members*
3,826 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Having problems with Cutter path not completing cut (PICS)
    Sep 2017
    Im having a problem getting a 1/4 ball nose emill to go to the exact edges of the part.
    It will work great when at 90 degrees. but when I turn the tool to a 45 degree fix. ( for clearance ) the tool doesnt go the the exact edge of the part.
    Im still very new to working with cam software. So it could be something fairly easy.
    Works fine.
    Doesnt work
    ks
    Sep 2017
    Re: Having problems with Cutter path not completing cut (PICS)
    Come on... no one can help me with this one? :banana:
    Jun 2008
    1838
    Are you using "Tool Center" or "Tool Tip" ? ?
    Dec 2008
    4548
    Quote Originally Posted by SNZO View Post
    Little information has been provided. On the previous dialogue page, what is set for the "Area type"?
    There are also about 9 other things that can control that. Let alone I cant be sure WHICH TOOLPATH Strategy that even is!!!
    Zip and post the bbcd file would help.
    Apr 2008
    1577
    Are you using any kind of tool containment strategy? If so, make sure it is properly projected while on a tilt. Sometimes it helps rotating the view in the workspace to look at the part the same way the tool will, looking straight down the shaft.
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
  1. cutter path
    By plcamp in forum Mach Software (ArtSoft software)
    Last Post: 09-27-2015, 12:16 PM
  2. Need help with cutter path
    By Sugam in forum Controller & Computer Solutions
    Last Post: 10-27-2011, 09:26 AM
  3. Path on for cutter comp?
    By forestbear68 in forum EdgeCam
    Last Post: 01-03-2011, 11:37 PM
  4. completing machine and need help on controls
    By ssutton in forum Waterjet General Topics
    Last Post: 06-14-2010, 11:33 PM
  5. takisawa not completing tool change
    By premacpmc in forum DNC Problems and Solutions
    Last Post: 09-02-2009, 04:58 PM
