584,833 active members*
5,695 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle cooling from water supply
Results 1 to 8 of 8
    Feb 2009
    15
    I am installing a water cooled spindle and have been looking at various setups. It dawned on me I have a 1/2" water line running right over my 36"x36" machine. I am thinking about tapping into the 1/2" water line with a solenoid valve and running a feed and return line straight down to the spindle and just running softened cold water for cooling. I'd dump the return into a sink next to the cnc. No radiator, no sump, no pump. There's no need for glycol in a system. Anyone see an issue with this approach to cooling a spindle?
    Apr 2013
    1899
    Re: Spindle cooling from water supply
    Yes, I see an issue with this. Most of the globe doesn't have enough fresh water for drinking and you want to waste water through this stupid solution. Why not create a closed system using a pump like everyone else?
    Dec 2007
    2134
    I can't understand why you'd run plain water through it. You wouldn't do that with your car radiator would you?
    Same for the spindle, a large bucket of radiator coolant with a small pump is all that's required, no algae growth, mold, or contaminants to cause rust.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Feb 2009
    15
    I would be using a pump, a well pump and the water goes right back into the ground. Actually I probably won't even be using enough water to kick on the pump. Obviously since you say my ideas are stupid you are much smarter than I am, probably better looking, and vastly superior in every way. I humbly submit to your dominance, will totally ignore your frivolous comment and get on with my life.
    Feb 2009
    15
    I've installed a variety of geothermal systems and the only reason to run glycol is for anti-freeze. It actually lowers the heat transfer capabilities of water. There's simply no need for glycol. I've never had any problem with algae, mold or contaminates causing rust in my residential system so I don't see where it would be an issue with this. It's well water running through a softener, double filter.. I run the exact same hose from the cold water to a refrigerator ice cube maker. Not using a sump. pump or radiator is just eliminating things that could go wrong.
    Apr 2013
    1899
    Wow... it seems you are the one who know everything, so why did you ask this question?
    Jun 2011
    692
    I don't think algae would be an issue, as it's a continuous flow of filtered (earth filtered..) water, but rust might be. Residential systems don't use much steel, I would think rust is part of the reason why.
    Feb 2009
    15
    Yes rust is my concern, good point.
  1. Monitor water cooling of spindle
    By slipery in forum Mach Wizards, Macros, & Addons
    Last Post: 05-06-2017, 12:57 PM
  2. Water cooling my spindle
    By johnnyt74 in forum DIY CNC Router Table Machines
    Last Post: 02-11-2017, 12:15 PM
  3. Spindle Cooling Water Connections
    By kolias in forum Chinese Machines
    Last Post: 10-26-2016, 04:32 AM
  4. Water cooling or air cooled spindle
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 12-25-2012, 01:48 AM
  5. Spindle water cooling 101. The right way.
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2010, 05:20 AM
