585,708 active members*
3,971 visitors online*
Thread: motor tuning
    Apr 2017
    Question motor tuning
    I have this kit [USA STOCK4Axis Nema34 Stepper Motor 9.3Nm 1600oz-in+Driver 85BYGH450C-012B CNC | eBay
    and 16 mm Ball Screw assembly 1000mm long and with 4 ball circuit | eBay
    I use MACH3 on Windows 7
    I set the driver to 1600 PULSE /REV
    I set in motor tuning:
    step per: 1600
    velocity: 1000 (for start)
    accelrtation: 100 (for start)
    step pulse: 0
    dir pulse: 0
    Then I used the axis calibration (set steps per unit)
    Now for the problem I have
    after axis calibration
    In MDI (any axis X, Y, Z)
    I am writing
    G00Y1.25
    Then the axis moves right to 1.25MM
    Then I press GOTO Z and it is 0.00MM
    Now again in MDI
    I am writing
    GOOY-1.25
    Then the axis moved 1.30 / 1.27 MM
    Then again GOTO Z
    And it returns to 0.00MM
    So there is no BACKLASH
    I can not set calibration
    Another thing I tried was plans at SOLIDWORKS and VECTRIC
    (Just 90MM square on 70MM)
    And the size Not going out right
    Can anyone shed light on the situation?
    *** I also tried to change a board but it did not solve
    Lazada Philippines: Online Shopping at Best Deals, Discounts & Prices!
    Dec 2007
    2134
    Re: motor tuning
    I'm wondering if it's the hardware at issue, that ebay kit is a really badly matched kit I suspect. The steppers are huge and have a massive inductance value, the ball park PSU they need to perform optimally is around 150VDC.
    How big and heavy is this machine of yours?
    More knowledgeable people will chime in I'm sure, but I think the response and speeds/rapids will be pretty bad with this setup?
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Apr 2017
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    Sorry I did not have time today and tomorrow I'll bring some more details about the machine
  1. motor tuning
    By Rajudh in forum Zen Toolworks
    Last Post: 12-16-2016, 04:24 PM
  2. Motor Tuning
    By clfrye in forum Mach Mill
    Last Post: 07-07-2012, 12:11 AM
  3. Motor tuning
    By Scruffynerfherd in forum Taig Mills / Lathes
    Last Post: 06-06-2012, 05:46 AM
  4. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
