585,967 active members*
4,278 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Emco compact 5 cnc lathe question
    Mar 2007
    We just buy a emco compact 5 cnc lathe, 3 gen and for now i have 2 questions :
    How we move the axe in manual mode ?
    How we made the origin ?
    Thanks in advance !!!
    Any ressource related to this lathe will be appreciate. Thanks
    Nov 2004
    Red face
    Quote Originally Posted by keny View Post
    Kenny,
    I also just got the Compact 5 CNC.
    To move the axis (I believe you mean) just put the machine in 'manual mode' either by pushing the rocker switch to 'manual' or by pushing the H/C button on the far right (will toggle from manual to CNC) then push the -X +X or the -Z or +Z. To go fast push (and Hold) the ~ button that's above the X & Z keys.
    I haven't figured out the origin for sure yet, I'm working on that one, but what the manual says is to enter a code of G92 with values for X & Z. It may work but so far I haven't figured that one out.
    I think you enter a code to go to an 'absolute position' from the G92 and then work everthing from there in 'relative'.
    I'll be trying that later today or tomorrow.
    I got this info from http://www.d-and-d.com/EMCO/MANUAL/index.html and I found this site through the Yahoo group Emco_cnc_users
    Good Luck and let me know if you have any good results,
    Steve
    Mar 2006
    113
    I just bought a Compact 5 CNC and I am trying to figure this out also. Usually you can set a zero and it stays but every time I come out of the programming mode the X and Z zeros are reset.
    Any insight would be great.
    Dan
  1. emco compact 5
    By h_2_o in forum Mini Lathe
    Last Post: 01-14-2015, 12:56 AM
  2. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  3. EMCO compact 5 PC to win XP?
    By SBruceSmith in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-29-2006, 08:30 PM
  4. Emco Compact 8
    By itsme in forum Mini Lathe
    Last Post: 07-07-2005, 08:54 PM
  5. EMCO Compact 5 cnc help
    By Bohdan2 in forum Uncategorised MetalWorking Machines
    Last Post: 02-06-2004, 09:02 PM
