Hi All,
Have a Hitachi Seiki VK45 with a seicos m2. CRT will not come on at power on. Can see a slight orange light at back of CRT tube but nothing on the screen and hydraulics and servos will not start. Ideas?
Hi All,
When you turn on the control does it fire up - I know you cant see anything on the control screen but look at the control rack and confirm that the lights on the cards are on/ blinking as normal
john
On the rack there will be boards that should have lights. If you aren't seeing any on any of the boards I'm guessing the control isn't firing up - likely the Power supply. Take another good look around the boards, there are stacks of led's on the long edges of them, you should see something if it does in fact fire up. Also when you power on the control the lights behind the buttons on the panel should come on to indicate the control turned on. Check these items out and let me know
John
I have no lights on the boards. Also, I dug a little deeper and found what I believe is the power supply (HS-01). It has terminals all the way across the top. All voltages are good except the 24v terminals. these are zero and there are two red LEDs lit on the board. LED2A and LED2B.
