585,748 active members*
3,424 visitors online*
Results 1 to 7 of 7
    Jan 2012
    57
    Question lifting the mill?
    Hi guys, I moved recently and need to lift the mill off its pallet.
    In the past I've borrowed a friend's engine hoist and a heavy tow strap, while it worked it was a bit of a scary procedure and always left me uneasy seeing the mill dangle with minimal control.
    Has anyone here used a forklift to pick up the mill from under the table (with some thick wood to protect the underside) ?
    thanks in advance
    Dec 2013
    5717
    Re: lifting the mill?
    What kind of mill? The table would not be my first choice.
    I normally lift from the ram. 2x4s under the ram ways.
    Or using straps, using 4 layers of cardboard to protect the straps
    Jan 2012
    57
    Thanks for the reply.
    I'm trying to lift my IHCNC / Charter Oak cnc mill, it weighs like 1k pounds or maybe 1.1k at most.
    I suppose I'd have to use tow straps with the fork lift if I try to lift it from the head (similar to how I did the with the HF engine hoist. It left me a little uneasy.
    Dec 2013
    5717
    Lifting on the column would be my choice, with a balance strap to the front of the machine somewhere. I'm surprised that there is no lifting hole through the column. You might be able to lasso the head right against the column, but you would want to strap the head down to the base so you are not putting any pressure on the leadscrew.
    The table will take a lot of weight downward, but is not designed to lift.
    Oct 2005
    99
    The 12Z has horizontal lifting holes in the base.
    Jan 2012
    57
    I talked to Tommy last night. Always enjoyed chatting with him. He's doing well and is enjoying his new job.
    He mentioned that he used to use a fork lift to move these mills around his shop.
    The preferred method is to place wooden boards under the table, move the head all the way down and move the table all the way back to get a low center of gravity. Moving the table back will prevent it from tipping backwards when lifted.
    He liked to lift from behind, but could also be done from the front.
    Since I want the stand to go close to a wall, mine will need to be lifted from the front.
    I will try to grab some pics when I do this in a couple of weeks.
    Jan 2012
    57
    Hi guys, I rented a fork lift and repositioned the mill onto its table. Worked like a charm and far safer (in my opinion) and less stressful than using an engine hoist.
    I had a komatsu fork lift with 5000 lbs lift capability, it managed to get into my garage easily and it was quite maneuverable.
    I put 2 pieces of wooden board under the table and taped them in place.
    I set the forks under the table, as close together as possible without contacting anything.
    After I lifted the mill up from the pallet an inch I tilted the forks inwards towards me to prevent the mill from tipping backwards, this cradled it nicely and I was able to hop out, remove the pallet and put the mill on the table without much trouble.
    I set it down gently and tightened down the screws holding it in place.
    Unfortunately in the excitement I did not have a camera handy. Wish I had remembered!
  1. Lifting Tormach lathe from pallet without lifting kit
    By Spiffy Lab in forum Tormach Slant Lathe
    Last Post: 01-02-2020, 06:20 PM
  2. Lifting an 86 QT10N
    By xa-mont in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-16-2014, 11:03 PM
  3. G0602 lifting?
    By thewoodnerd in forum Benchtop Machines
    Last Post: 10-18-2011, 04:05 AM
  4. Lifting Mill?
    By CROSSHATCH in forum Charter Oak Automation Support Forum
    Last Post: 11-22-2008, 08:33 AM
  5. z axes lifting
    By John Teichman in forum Mach Mill
    Last Post: 02-11-2008, 04:12 AM
