586,022 active members*
3,638 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > how can be more convenient and high efficiency for milling drilling CNC
Results 1 to 1 of 1
    Appliction
    For milling and grinding process, CNC or FMS centre, heavy duty cutting, lathe, mold grinding,turning machine,metal cutting process
    Feature
    Pole size:50 x 50
    380kgf for each pole
    Magnetic field depth:10mm
    5-sided machining is possible in one clamp
    Key words
    Magnetic workholding /magnetic clamping/electro permanent magnetic chuck/workpiece/magnetic tools /holding force/clamping force/magnetic plate/Machine Tool Accessories/CE certification/connector cable/electro plug/control master
    Last edited by vivimagnetics; 09-28-2017 at 05:44 AM. Reason: http://img002.hc360.cn/k3/M09/45/77/wKhQv1m3ml6ENRvwAAAAAClxR0s508.jpg
