585,717 active members*
3,995 visitors online*
Results 1 to 6 of 6
    Aug 2005
    6
    Fanuc power unit problem
    Hi every one;
    We have a Fanuc 6M controller with power unit
    type:A14B-0061-B002-02.Our problem is that the
    machie will not start to work when we push the ON(start)button.
    The main relay behind the controller will be activated and ,soon after, deactivated and the red ALM(alarm) LED on the I/P unit board
    (A20B-0007-0340-06A) will turn ON.
    BUT WHEN WE PUT A READING LAMP NEAR THE POWER UNIT FOR
    ABOUT 5 MINUTES BEFORE START(I HAVE SHOWN THE AREA ON
    THE ATTACHED PICTURE),THEN EVERY THING WILL BE OK !!
    1-Does Aaybody have exprienced this problem?
    2-Does anybody have schematic diagram(circuit diagram) of power unit?
    Atleast the diagram of the area that we have problem in there.
    3-In the attached picture I have specified 2 capacitors which will
    get to hot when the machine is working.It seems this is not normal,
    Am I right?
    Please help us what is our problem.Is there any element or part
    in Fanuc 6M to be sensitive to enviroment temperature(and our problem
    is of this kind)?Do we have any problem regarding over current problem?
    Thank you in advance.
    Bahmanpour
    Attached Thumbnails Attached Thumbnails A14B-0061-B002-error description.JPG
    24220
    I think those 'Capacitors' are actually resistors? At least that is what it appears you have pointed to.
    The symptom you have sounds like a classic symptom of short on the DC output, most likely on the 24vdc, I would disconnect the 24v connections on the RH side of the PS one at a time and see if it stays on.
    The last one I had, was a shorted 5v regulator (24vdc fed) on the video board.
    It can also be limits switch etc shorted.
    Al.
    Albert E.
    Aug 2005
    6
    Thanks for your reply Al The Man but if we have Dc shortage or
    24V problem or limit switches fayulty or any other probelm,why the machine
    will start to work after we warm up the specified area on the PS unit?
    What do you mean by "the capacitors are acually resistores"?
    Do you have the schematic (circuit)diagram of this section?
    WHY WE DO NOT GET ANY ERROR MESSAGE AND ALARMS FOR LIMIT
    SWITCHES,if they are supposed to be faulty?
    Sep 2003
    552
    There is a good block diagram of that unit in the maintenance manual.
    I have put together a 15 piece kit that repairs 90% of the problems with that unit. The price of the kit is $30USD + shipping.
    Darek
    Apr 2004
    61
    I have the same problem Now, did you find out what it was?
    How did you solved?
    Quote Originally Posted by sbp View Post
    Jorge B.
    jorbercnc.com
    Apr 2004
    61
    Quote Originally Posted by HillBilly View Post
    Darek
    Where can I get that kit?
    Jorge B.
    jorbercnc.com
  1. Fanuc power input unit (A16B-16000090/05B) ALM LED (RED)
    By kccement in forum DNC Problems and Solutions
    Last Post: 10-31-2012, 03:18 PM
  2. FANUC POWER UNIT A14B-0061-B001
    By Shanghyd in forum Mori Seiki lathes
    Last Post: 03-26-2012, 05:07 PM
  3. Replies: 0
    Last Post: 11-14-2008, 01:02 PM
