585,930 active members*
4,157 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics Centurion 6 CNC Control
    Sep 2017
    5
    Hi My name Is Allen, I purchased a 823 wells Index with Centurion 6 Control_ CNC update done 1998. I picked it up took it to my shop and got started using it right away. I ran 25+ parts through for and upcoming job. All of a sudden every time I hit the reset button for resetting drives the whole computer would reset and soon there after it just started resetting over and over until it finally quit and wont reboot now. The reason I am writing you besides reading your past post it seems you have a deep understanding of there machines is your mentioned the CR29 relay and you dint explain further on a past post of yours. I am asking because I noticed this would flash its LED Indicator every time the computer tried restarting and now its not on at all. I followed the Troubleshooting steps you mentioned in the past post I am referring too. I found I had 21V on T12 side and traced it down to a small short in a limit switch for Z wire. I fixed that and then moved on to find the last guy who had this did a bad job hooking up the main power plug cap so I tighten all that. Now I still cannot computer to boot I now have 23.5 V on T12 to T22 and consistent weather I have FPP plugged in or not. Is the 23.5V enough to stop CPU from booting? Could it be over .5V? If so I guess its time for a new 24V power supply. I checked the one inside the CPU and its has correct voltage across all wire combinations. I don't have CR29 Led light on and I dont have CR1 light on this makes me think I have a bad CR1 relay or possibly both CR1 and CR29. What is CR29 for? Where is CR1? Thank you for your help. Also do you have an electrical schematic for a Centurion 6 or close?
    Sep 2017
    5
    Re: Milltronics Centurion 6 CNC Control
    To All who May help I'm sorry if this worded weird. I was trying to reply to another post but I would love to hear others input as well. As an update I contacted Milltronics and was able to narrow down my particular setup and he sent me the schematic. I have attached it for the communities use. I have also found that indeed my issue is a Chip out fault not telling CR29 to ground and then causing CR1C to not ground so I am sending the Chip cabinet in to be serviced and updated as much as possible usb drive/ networking new software on Desktop, Remote keyboard etc. I love this machine and its my first experience with CNC and I figured out how to program it in 2 days using conversational I haven't graduated to G code yet but I am interested!
    https://files.acrobat.com/a/preview/...6-e94549f48604
    Jul 2010
    548
    If you haven't sent the control in yet, PM me or call 952-288-6340
    sportybob
  1. Milltronics Centurion 6 CNC Control
    By aaautoglaze in forum UCCNC Control Software
    Last Post: 09-30-2017, 12:15 AM
  2. Milltronics Centurion IV DNC?
    By papp101 in forum Milltronics
    Last Post: 01-04-2014, 03:57 AM
  3. Milltronics Partner V with Centurion IV Control
    By alvaallenii in forum Community Club House
    Last Post: 08-20-2013, 01:51 PM
  4. Replies: 3
    Last Post: 03-27-2010, 03:47 AM
  5. Milltronics Centurion Six
    By CUTRITE in forum Milltronics
    Last Post: 10-13-2006, 07:48 PM
