585,970 active members*
4,500 visitors online*
IndustryArena Forum > CAM Software > CamWorks > G43 code in UPG
    Jul 2013
    84
    Angry G43 code in UPG
    Hi forum,
    due to my setup Tool offset is redundant (et. problematic) so I need to strip it out of my post processor
    for the life of me i have scoured the UPG to see where to remove it but not having much luck
    any guides (BTW generic Fanuc used)
    Oct 2009
    10
    Re: G43 code in UPG
    In the UPG go to sections, rapid moves, 1st rapid z down. Delete the <G:43>
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. Program to Convert Mill g code To Laser g code - CMTL
    By doanwannapickle in forum Visual Mill
    Last Post: 02-20-2017, 06:08 PM
  3. mach3 crashing with run of code/drilling holes through table with other code
    By normalform in forum Mach Software (ArtSoft software)
    Last Post: 07-28-2014, 03:38 AM
  4. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  5. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
