585,715 active members*
3,870 visitors online*
IndustryArena Forum > CAM Software > CamWorks > More Confusion - need sanity and sounding board
    Jul 2013
    84
    Hi forum,
    I have been working my way through tutorials and videos .. any I feel quite confident, however i am not getting the results as expected so looking for some guides:
    from research- much of what i need to achieve will be via EC-Edit, and mostly via section:
    I make all the mods to the file, save, go to UPG re-compile, the re-select CTL from Cam works in SW, pots process = Nadda- no change !!! at all.
    Trying simple things such as Gettools (show all tools at start of tape) / remove G43 via first rapid move Z down
    so here is what I have:
    CTL file - C:\Program Files (x86)\UPG\ctl\SHERLINE2017MACH3.ctl
    Mach3Sherline
    GENERIC FANUC MACH3
    136.65200mm
    76.20000mm
    SRC file:C:\Program Files (x86)\UPG\Millsrc\Sherline2017Mach3.SRC
    when I open SRC file in EC edit i get this under library files:
    :LIBRARY=C:\Program Files (x86)\UPG\Millsrc\Sherline2017Mach3.LIB
    :LIBRARY=C:\Program Files (x86)\UPG\Millsrc\MILL.LIB
    i modified Mill.LIB to show tools in start of tape section (no change)
    Sherline2017Mach3.LIB did not have any sections - so added a section to use get tools (no change)
    What the heck am i doing wrong here?
    Oct 2009
    10
    Re: More Confusion - need sanity and sounding board
    You may need to move the ctl file after you compile it. Or change where Camworks is looking for the ctl file.
    Right click machine then the post processor tab to see what the active post location is.
    My posts compile in the upg ctl folder but camworks uses the camworksdata\posts folder.
    Jul 2013
    84
    Quote Originally Posted by Georgefs View Post
    give it a go thanks for the view
    Aug 2005
    You might have solved this already but for others of us... we need to re-select the .ctl file in the Machine Config window. I watched this video and starting at 22:50 he discusses this. https://youtu.be/vXe0s5IbpC4
    Brian
  1. Need a Sanity Check
    By xTourniquet in forum USA Club House
    Last Post: 08-14-2014, 08:34 AM
  2. Z axis sounding really rough
    By functionbikes in forum Tormach Personal CNC Mill
    Last Post: 06-13-2010, 06:22 PM
  3. Sanity check design please...
    By Rarius in forum DIY CNC Router Table Machines
    Last Post: 03-12-2009, 01:50 PM
  4. Newbie sanity check
    By mmm in forum DIY CNC Router Table Machines
    Last Post: 11-10-2008, 05:34 PM
  5. Horrible sounding 8x12 motor please help !!
    By Dan S in forum Mini Lathe
    Last Post: 04-08-2006, 05:27 PM
