585,743 active members*
4,802 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP 5000 blanks out
    Jul 2005
    380
    OSP 5000 blanks out
    I have a gorgeous Okuma LB-15 lathe, with OSP 5000L (green screen) CNC. My dad bought this machine brand new in 1983 and it's been mine since new. I took it out of the box, and was the only one running it.
    The machine was offline for a while and I've just put power to it. She fired up and came alive no problem.
    I noticed that the CNC would "blank out" - the CRT and the green led's on the control would go dark, but the hydraulics and everything else would stay running. The only way to recover was to power down, and then power back up. I can't be 100% sure but it seems to go down when the way oil pump shuts off, but that could be coincidence.
    Has anyone had a similar problem? What was the fix?
    Could the CRT/Keyboard be going bad?
    -Doug
    Jul 2005
    380
    Re: OSP 5000 blanks out
    OK, update.
    Seems the OSP has it's own power source to the CRT Keyboard unit and age has taken its toll.
    Aug 2012
    164
    If you need parts for that, you can contact us at [email protected]. You can also check out okumaelectronics.com
    Jul 2005
    380
    Cool. Thanks.
  1. Retrofit Prolight 5000 (Benchman 5000) to run Mach
    By Impyman18 in forum Benchtop Machines
    Last Post: 07-10-2019, 04:12 AM
  2. TTS Blanks
    By JimsMachining in forum Tormach Personal CNC Mill
    Last Post: 03-07-2015, 07:20 AM
  3. RFQ:aluminum blanks
    By p38nut in forum RFQ (Request for Quote)
    Last Post: 01-05-2012, 04:37 PM
