584,837 active members*
4,934 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > Controlling Automated Laser Ablation Machine
    Sep 2017
    Question Controlling Automated Laser Ablation Machine
    Hi all, newbie here,
    I am planning to build an automated laser ablation machine. Will be ablating (removing) rust from steel on flat platforms only.
    My question is regarding the controls of the gantry system that I plan on building.
    Gantry will be 1000mmx1000mm, XY axis only controlled using NEMA 23 stepper motors. Z will be controlled manually.
    What do i need to use as the brains of the project (tiny g, cnc xPRO, smoothieboard etc) if i just want the laser to be going back and forth then up x amount of distance.
    Basically repeatedly the same motion over and over, then going back to the it's origin (0,0). No complex designs with the laser or any CNC-type movement.
    The gantry will be held on a chassis with wheels so it can't be fixed. This is a must.
    Can someone point me into the right direction? This is my first Gantry/CNC type project as a final year student in mechanical engineering. I've been doing a lot of research with regards to control and automation. I have extensive experience with programming in C++ and Arduino type stuff.
    Thanks for the help,
    Cheers
    Apr 2006
    108
    Re: Controlling Automated Laser Ablation Machine
    This type of laser “cleaning” machine has been made by a Chinese company over 6 years ago. I remember seeing a demonstration of how it works.. as a hand held “laser spray gun” that cleaned the surface of the metal. It was cool, but obviously dangerous. .. and I didn’t need it at that time.
    Ray Scott
  1. Automated Coffee Machine
    By Endurance in forum Other Machine Topics
    Last Post: 08-28-2013, 08:58 PM
  2. Welding on a automated machine
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-09-2012, 01:27 AM
  3. Automated Oil tank sandblast machine
    By Farmers Machine in forum CamSoft Products
    Last Post: 12-25-2011, 01:18 AM
  4. Automated Insert Dispensing Machine
    By wildebs_27 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-12-2009, 01:46 PM
