585,760 active members*
4,019 visitors online*
Thread: V30 Post
    Oct 2004
    832
    V30 Post
    I am contemplating upgrading from V27 to V30, probably just Lathe (unless I get a cracking deal ) as my mill stuff is basic and V27 works great for me but the Lathe side seems to have taken a huge step forward just like V27 did.
    Anyway I was wondering if anyone knows whether a Lathe post processor for V27 would work in V30?
    Usually I could just try it but looks like you no longer get code for the first few days with the Demo
    My Posts have quite a few things customised in them hence the reason I am asking.
    Dec 2008
    4548
    Quote Originally Posted by Hood View Post
    Dealing with your customizations can be pretty straigt forward witha good diff program (i have one). Some of the variables and blocks have changed a bit, so that needs a trained eye to convert. The more important change would be in the posting engine itself. So i would definitely want to start with a v30 base.
    Without posting your actual customized post here, can you point to the base post that you started with to customize your current one? I can give you some insight to the difference.
    Also, you should contact bobcad to get a "posting demo" working... i am pretty sure they would do that for you....
    Oct 2004
    832
    Re: V30 Post
    Thanks for the reply BurrMan.
    To be honest I can't remember all of the things I did but I know threading was one, tapping was another although that may just have been on the Mill one, will have to look.
    It was originally a Mach3 metric post I think, probably a V24 or maybe V25.
  1. Replies: 3
    Last Post: 11-30-2016, 07:28 PM
  2. Replies: 0
    Last Post: 07-24-2016, 08:43 AM
  3. Special post for presentation! Laser manufacturers/dealers post their contacts here!
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2010, 07:23 PM
