585,698 active members*
3,393 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 32i, spaces removed in Auto mode
    Jun 2008
    113
    Under program check the code is shown as G0X123Y342... and in edit mode G0 X123 Y342... I guess there is a parameter for this?
    Thanks again.
    May 2016
    30
    Re: Fanuc 32i, spaces removed in Auto mode
    on the Fanuc 32i there is a soft key option whilst in edit mode to "Change Editor" one has spaces the other does not. Use the left-right soft keys in edit mode and you should see the "Change Editor" soft key.
  1. Hitachi VK45 won't run in AUTO mode
    By Dancy in forum Hitachi Seikis
    Last Post: 02-19-2020, 07:15 PM
  2. fanuc controls outputting double spaces
    By craneaid in forum Fanuc
    Last Post: 12-26-2014, 09:52 PM
  3. Adding Auto Mode
    By Jerry Shorter in forum LinuxCNC (formerly EMC2)
    Last Post: 06-17-2010, 02:38 PM
  4. Auto mode only after single block
    By fomaz in forum Fanuc
    Last Post: 04-17-2010, 10:53 AM
  5. T MSR AUTO MODE IN MAZAK!
    By sridhartsr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-28-2009, 10:34 PM
