586,009 active members*
5,022 visitors online*
Page 2 of 14 123412
Results 21 to 40 of 265
  1. #21
    Jun 2003
    2103
    Kammo try this one. R12 version but maybe it will work for you.
    Attached Files Attached Files
    No greater love can a man have than this, that he give his life for a friend.
  2. #22
    Quote Originally Posted by turmite View Post
    Mike, the only thing in that file is the binding, cutout outlines, inlay outlines and the nut. You may need to convert the surfaces to meshes before saving to .dwg
  3. #23
    Jun 2003
    2103
    Gerry are talking about something like a 3ds mesh, polygons?
    Mike
  4. #24
    Kammo1,
    Try this file.
  5. #25
    Quote Originally Posted by Mike Stevenson View Post
    Kammo1,
    Try this file.
    Mike, AutoCAD 2002 won't open that file.
  6. #26
    Sorry about that. I have ACAD 2006 and had no problem. I will try to post an earlier version later today.
  7. #27
    This time for sure! :D
    ger21,
    Try this one please.
  8. #28
    I can check tomorrow with 2002 at work. However, there are no surfaces or meshes in the .dxf. There's enough info to get the neck shape, but nothing for the carved top. Getting closer, though.
  9. #29
    ger21, buddy, I can give you this file in any flavor you want. I have a pristine solid of it.
    Name it and you got it.
  10. #30
    Thanks, but I don't need it. Just pointing it out for others.
  11. #31
    What kind of file should I post to get it?
  12. #32
    I would think you can save a .dxf from rhino that converted the nurbs to meshes, but I don't know how to do it.
  13. #33
    And waist one of my last 23 saves?:banana:
  14. #34
    Feb 2005
    168
    I managed to open the file Mike many thanks, is this just a flat top Les Paul as I couldn't see any indication of the carved surface that you see on a Les Paul top or am I doing something wrong ?? would lovr to see the guitar with a carved top many thanks again
  15. #35
    If at first you don't succeed....
    Okay my fellow Les Paul Carve Top enthusiasts here is a file I hope you can all use.
    P.S. Sorry not you ACAD "only" guys....
  16. #36
    Feb 2005
    168
    Hi Mike I saved the file which is an igs file but Autocad will not open the file, it must be me am I doing something wrong. I have Autocad 2005. Magnus the file you sent me which was a sat file Autocad will not open either. Many thanks guys for being helpful and patient CHEERS! Would it help if I rename the file as .dxf or.dwg would this help before I screw it all up.
  17. #37
    AutoCAD won't open iges, but can import some versions of .sat. But you don't use "open" with an .sat file. Try Insert > ACIS file
  18. #38
    Kammo1,
    As I stated in Post #35, "P.S. Sorry NOT you ACAD "only" guys...." I will try to post an ACAD file you CAN read today (SAT.)
  19. #39
    Feb 2005
    168
    Mike sorry I didn't read the post correctly, ger21 I don't understand when you say insert ACIS file where do I do this ?, oh boy this is getting frustrating as my computer knowledge isn't very good and without understanding what, to do where and when I feel like I'm going around in circles........
  20. #40
    Quote Originally Posted by Kammo1 View Post
    Insert menu. Insert > ACIS file..
Page 2 of 14 123412
  1. Surface body, Solid body
    By CAD123 in forum Community Club House
    Last Post: 09-11-2013, 02:00 AM
  2. Adding solid body
    By crolee in forum Mastercam
    Last Post: 04-30-2013, 08:53 AM
  3. Les Paul Hollow Body Copy
    By gregmary in forum Musical Instrument Design and Construction
    Last Post: 04-11-2011, 12:55 AM
  4. Ibanez jem 77 solid body
    By rockerfx in forum Musical Instrument Design and Construction
    Last Post: 07-10-2008, 12:07 PM
  5. Solid Extrude Cut Body
    By Mastercam User in forum Mastercam
    Last Post: 12-01-2007, 05:48 PM
