Hi
I'm wondering if there is an opportunity to use WARP for:
1) to find the side
2) to find the center of a circle
3) aligning the X and Y axes relative to the workpiece
Hi
1) to find the side
this is not exactly what I wanted to do
see the picture
can the board remember points 1 and 2
that the Y and X axes take the directions of the sides a and b
This feature is called "Transformation". It is heavily used when milling PCBs. There are some tutorials available on our web site.
how many mobile sensors can i use?
judging by the image I can use 2
I also need a link to the sensor programming language
And I can create buttons for my search scripts? (I do not quite understand how to call them)
or I can create only 2 scripts: "measure offset by Z", "measure tool offset"?
TNG sw user manual(regarding script language) is currently in development. thank you for understanding.
In TNG you are able to create your own user defined scripts that would suit your needs. They are located in "PlanetCNC64.Scripts" folder in main install directory.
User defined scripts are called:
Machine.UserDefined_UD(1,2,3...).gcode
Currently there is in-built feature for measuring surface of material located at the left toolbar or in Machine Menu: Machine/Work Position/Measure
You can also use in-built feature "Measure Surface", which measures grid of points over material surface in order to use "Warp" feature.
We intend to create in-built features for measuring of inside/outside corners of workpiece and centres of holes or cylinders.
