585,977 active members*
4,113 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Pulsar spindle nut wobble
Results 1 to 16 of 16
    May 2017
    18
    I just got a new Novakon Pulsar last week and finally turned it on today. I removed the lever drawbar assembly before I did this as it seemed to need adjustment and I didn't want to risk running it if the plunger was touching the spindle nut. When I ran it at low speed, I can visually see some runout, or wobble even, on the spindle nut itself. I haven't put an indicator to the actual spindle nose, so I don't know if there's a problem there, but visually it looks like everything is spinning true down there. I was just wondering if anyone knew if this was normal? Like do all spindle nuts have some visible wobble? I just haven't seen that many tools to say. Thanks in advance for the help.
    May 2017
    18
    Re: Pulsar spindle nut wobble
    Here's a video of it I took if it helps diagnose. Thanks again.
    https://www.youtube.com/watch?v=XfedmbLxSJY
    Feb 2006
    7063
    That does not appear to me to be necessarily a wobble. Looks to me more like optical illusions. You're looking at the top of the drawbar head, which is partially, and very unevenly, burnished by contact with the LDB. You're also seeing the top of the spindle, which is tubular, and threaded on the OD. The end of the threads are, surprise!, not consistent around the whole OD, due to the thread lead. So, to me, it looks perfectly normal.
    Regards,
    Ray L.
    Aug 2007
    701
    Mine looks the same. Fortunately my spindle is fine down below. Btw I never had great luck w the lever drawbar and just made my own power drawbar. My LDB always rubbed.
    Feb 2006
    7063
    Quote Originally Posted by brianbonedoc View Post
    I'd guess you have a fairly early LDB? It has been greatly improved over time - more travel, more spring pressure, etc.
    Regards,
    Ray L.
    Aug 2007
    701
    Yes or so I’ve heard. Great idea but V1.0 didn’t work that hot.
    May 2017
    18
    Yeah, I only had mine off because when I first tried it, it seemed "sticky." When I took it off to get that video, I found that the cam shaft was slightly bent, and even though it was supported by two bearings, it didn't rotate freely.
    I really like the idea of the lever drawbar, but I'm now also trying to think of a better solution than the current one. I've seen your videos of your PDB. It looks really slick. Do you have the plans for it up anywhere?
    Thanks for the reassurance that my spindle is ok.
    Aug 2007
    701
    Yeah I will try to post the files later. I really have to say it’s the second best upgrade to the pulsar - by far #1 has been PathPilot.
    Aug 2007
    701
    rickjames - heres the link to my Fusion 360 file for the PDB: A360
    Just double check that the base fits your pulsar as you may have a newer version. Also my air cylinder is the Fabco MP4 (4 stage) but really only needs 3 stage. 2 stages won't supply enough pressure.
    I did add a stack of 12 bellevilles from mcmaster to give over 3000lbs of holding pressure and a longer stroke of the drawbar. It never pulls out even when I screw up the feeds and speeds and cause crazy chatter like it used to w/ the LDB.
    Jun 2004
    6618
    I removed the LDB early on too.
    After lots of fiddling, just went back to a butterfly impact. With manual tool changes, it's hard to get more convenient than those.
    Lee
    Aug 2007
    701
    Quote Originally Posted by LeeWay View Post
    I tried the impact wrench thing but I hated the noise and i always over shot it and the collet would drop out
    Jun 2004
    6618
    Took a little getting used to.
    Lee
    Jun 2006
    3063
    Novakon is still selling Ray's PDB aren't they? That looked like a nice system. I'd be tempted to buy one if there was a model for my Tormach mill...
    Jun 2004
    6618
    Not sure if it will run with Path Pilot yet.
    Lee
    Jun 2006
    3063
    Good point, but I never upgraded to an ATC so tool changes are manual for me anyway. PathPilot shouldn't care about that.
    Jun 2004
    6618
    Right and I think I remember Ray saying that it doesn't matter for PDB. Must be easy integration on all of them. I have never thought about installing one, so don't know how they are activated.
    On the Slant Pro lathe, I had a couple of codes already in Path Pilot for the collet closer integration and bar puller. I imagine they have similar on the mill side for the PDB.
    Lee
  1. Pulsar spindle power?
    By brianbonedoc in forum Novakon
    Last Post: 04-23-2016, 05:04 PM
  2. X3 table has a lot of wobble
    By upjeeper in forum X3/SX3/G0619/G0463
    Last Post: 08-23-2015, 10:50 PM
  3. Spindle WOBBLE?
    By sheepdog in forum Uncategorised MetalWorking Machines
    Last Post: 01-25-2012, 07:30 PM
  4. 7X wobble
    By nateman_doo in forum Mini Lathe
    Last Post: 11-07-2010, 10:08 PM
  5. Multiple spindle or CNC? with wobble broach capabilities
    By Speedlox in forum Mechanical Calculations/Engineering Design
    Last Post: 07-23-2006, 05:05 PM
